Starting Issue
Had not used the car for a couple of weeks. Battery fully charged on CTEK. Car struggled to turn over as if starter motor was slightly jammed but started. Also power steering not working fully. After 20 miles started normally and power steering normal. Since done 100 miles and car is as new. Has done this once before several months ago. Any thoughts would be helpful!
That's your cars way of telling you that you need to drive it more often. Honestly, without regular exercise these things are to be expected.
I almost think you would be better off pulling the battery if you are going to leave it sit for a month or more vs. have it electronics 'asleep' that long. The car is always pinging the key fob and waiting to wake up.
Received 2,263 Likes
Queen and Country (08-27-2017)
I don't do this, never had a reason to try. BUT... my wife's Lexus RX won't work this way. Her brake NEEDS to be depressed before the START button is pressed or it won't do anything.
Cee Jay,
My 2007 LS460 was the same. I thought all cars worked that way and didn't realize that you could press the START button before stepping on the brake pedal until my Jaguar service advisor told me to try it after my car wouldn't start. I was sitting in my XKR chatting with him after having routine service and must have inadvertently pumped the brake pedal, and when I stepped on the brake and pushed START nothing happened. Pressed START then tapped the brake pedal and it started right up. Been doing it that way on both my Jags ever since.
Stuart
Stuart
Don't worry about it ,mine did it today, and it is on trickle charge every night, next to new battery and a daily driver these cars are known for electrical glitches, you probably get in one day and you'll have no power at all, then in a few minutes it will spring into life. The joys of owning an xk
Stuart S (08-27-2017)
Thanks Ralphwg just a lot on at the moment, at the moment contemplating moving up to a F-Type, but have driven a few, love the noise but something still doesn't give me the same pleasure as the xkr, will probably opt for an last production of the xkrs, to me the xk has more presence.
as with you mine on charge every night, but is used everyday, and doors locked, suppose some of us have and others not, it doesn't bother me as i just call it the rebooting mode when something goes wrong
