Starting issues
Starting issues
On occasion (random) on pushing the start button the engine will crank without starting unless I give it gas. The other starting issue is it will immediately start and then die immediately unless you give it gas. It is at the dealer now (fortunately CPO) and of course they cannot duplicate the problem. The didn't give me the code numbers but, they have high voltage, low voltage and starter button codes. To me it seems more like a fuel pressure issue but, that may be old school thinking. Has anyone else had this experience?
Dave
Dave
So the dealer did a software update and tested the battery and said it only had 509 CCA. Is this an issue? Barrery is only 2 years old and installed by another dealer in town. I'm going to see if there is any warranty on the battery. BTW Wanted $300 for the battery and installation. Any advice???
Dave
Dave
If it is a daily driver, the case for an AGM is not as strong.
DaveC (01-17-2015)
