Starting problems...again
Previously I thought that I had a bad tank of gas [and maybe I really did]. For a while everything was running fine but today I went to start my 2007 XK and it started - then died (as if it is not getting enough fuel) . On the third try I gave it gas so it wouldn't die and it stays on and works as normal.
Thoughts?
Thoughts?
Thoughts?
Thoughts?
I sometimes have issues with mine starting and then sputtering as well. It's never died but I usually give it a little gas to bump it up to about 1000RPM for a few seconds then it will settle on out. I have a bluetooth OBD2 dongle on the car all the time and this never produces a code. I'm thinking about trying some injector cleaner.
jagtoes (02-22-2016)
I recall reading here about a higher ethanol winter blend fuel problem, as my 08 was doing the same thing. This was in the late fall, and I have not had the issue since, after starting to run only 93 Exxon. Not sure if that fixed it, the fuel maps reset, or the fuel blend changed. There is a tech bulletin for it outlining a dealer fix. Search winter fuel ethanol, etc and it should pop.
The gas pedal operates more than the gas, it also opens the throttle body and gives it air. The problems you describe can easily be air starvation, caused by several things. When you start an engine it automatically chokes the air to give the car mainly only fuel. Just a tiny bit of air for combustion. If your sensors readings are wrong or air passages (throttle body/ intake) naturally choked that it would essentially be too much choke, which you then solve by putting your foot on the gas.
Chevron Techron is the best stuff on earth- should be used religiously, its totally safe and it totally works.
You can use techron to manually clean stuff as well.
kr98664
17
10-05-2017 06:39 PM
UntouchablesInc
05-21-2014 09:29 AM
