Steering screech...
Steering screech...
Another day, another woe...
Yesterday, tried to take the XK for a small journey and when driving out of my street I heard a screech (not sure how best to describe it, a sort of "krrrrrrrrrr" sound) when turning right.. Got the impression it what coming from right (driver side) but can't be 100% certain. I immediately stopped in the nearby street. Slowly turned a round...screech again. and sounded even when driving straight although less loud I think...
So parked th car back on my driveway and took my other car...
I tried to have a look underneath today but can see anything obvious. I looked at the steering fluid and it seems quite low (although car had full service a couple of month ago).
Any idea what it could be or what I can attempt to check the possible cause (whiteout causing more damage). Worst case I'll call AA but I like to have an idea of what I'm dealing with before.
Also wondering if to could be related to the intermittent noise I reporting in this thread
Many thanks
Many thanks
Could be the accessory drive belt slipping due to a worn belt, pulley or tensioner. Turning the steering increases the load on the belt. See if you can get it to make the same noise by blipping the throttle or turning the steering whilst standing still. If you can get it to do it again, spray some water on the drive belt and try again. If the sound goes away when the belt is wet then it is the belt.
Richard
Richard
Once you have located the belt, it's easy to spray some water on it with a water pistol or houseplant spray gun. You can even use a WD40 aerosol as the plastic pipe makes it easy to reach but just a quick spray for a second or two should be all you need.
Richard
Thanks Richard.
Did a little bit of testing just now. No clacking noise when starting (last time I had a couple of "clacks" when I started it) and I tried to turn the wheel when standing still and when driving in the street and it didn't reproduce the noise I had at the week end... 🤷♂️🤔 When turning the wheel to the max to the right it did buzz a little but nothing like last time.
I'll keep and eye on it but believe (and pray! 🤣 that it might be the belt indeed.
burmaz
03-22-2012 09:03 PM
marc4sgr
02-20-2010 08:20 AM
