steering wheel rake not working
have had the column apart today and all components function as they should but when all together it won't work properly,it now operates from the switch but will only move about 5mm at a time in any direction.the tilt(up/down) worked ok before now it doesn't just moves 5mm then stops and the in and out movment is the same.
I have tried two column switches and two small electronic solenoids that engage in the long worm gear.All other components cables all check out ok.
hisport
20
02-11-2024 11:19 PM
Alli Quinninho
12-22-2020 03:00 AM
Probesport
06-23-2017 03:20 PM
