Steering Wheel Shimmy
ORIGINAL: CRGrona
Thank you very much.
I am new to this site. Maybe you can inform me why my questions go to the 2007 & Up forums rather than the 1997 & Newer forum?
Those vibrations are usually due to out of balance wheels. Could be tire related (flat spots, uneven wear due to alignment, etc.), wheels that are bent (pot holes, curbs).
I would take the wheels out, clean them completely,check thetires for wear,balance them and try again. You have no idea how much road grime can affect the balance, asphalt and rocks stick to the inside... so clean them well.
Could be far off... but you never know... check that it does not have fix-a-flat in there... that would cause vibrations at those speeds as well...
If everything checks out on the tires and wheels the next thing to check is alignment and front end links.
FS[SouthWest]: Momo Wooden Steering Wheel
RobertTheBloke
09-24-2015 11:48 AM
