Steering wheel vibration at low speed turns only
I'm having what I think is a slight problem with my XKR (2010). From a standstill, if I slowly accelerate and turn the wheel to the right or left, it rapidly vibrates for a few seconds then stops. This is the only time this is occurring. I also hear a slight whine at idle but I'm not sure if this is the supercharger or something going on with the power steering that could be linked to the vibration. Thoughts?
I have this same problem on my 2010XKR and there are others as well. There is another thread from a couple of days ago where a TSB is mentioned. I previously read one where a power steering hose had to be replaced. I'm doing that in the next week or two.
It's sort of a shuddering feeling, correct?
Khan (02-14-2015)
i have this same problem on my 2010xkr and there are others as well. There is another thread from a couple of days ago where a tsb is mentioned. I previously read one where a power steering hose had to be replaced. I'm doing that in the next week or two.
jeffn (06-18-2016)
+1. My 2008 XKR does something similar at low revs when maneuvering. It's almost like the pump has to build pressure then release it to the rack. At first I thought the fluid had gone soft, but as amc says, it seems to be a harmless Jag feature/foible.
it happens in mine as well, not a full lock turn but a stopped 90 degree left or right turn, small vibration, sort of feels like the tire is slipping over a surface. dealer said they could never replicate the issue. it's a weird sensation and doesn't happen every time either, maybe 20% of stopped turns, and never while reversing. Also it happened on my stock rims and the new ones.
I would love to know what it is.
Received 1,124 Likes
jeffn (06-18-2016)
tonimccloud
19
01-18-2020 01:56 PM
