Stereo Upgrade for XKR 2007
Old 10-20-2020, 06:58 AM
Jungocat's Avatar
Here's what I did on my '07 with $20 in wrap and 2 evenings removing/wrapping/replacing the dash pieces......
Looks pretty good huh?
Modern look if you're not a wood dash guy/purist
Just need new mats and aluminum pedals
Take your time and use rubber medical gloves to remove each piece - and don't worry if you mess up applying the wrap, the wrap is super cheap
Easily undo screws....
Clean with 50/50 isopropyl alcohol (see YouTube videos for tips)
The following 2 users liked this post by Jungocat:
gts055 (12-31-2021), Stuart S (10-20-2020)
  #122
Old 10-20-2020, 09:23 AM
peterv8's Avatar
Mods, please move this post to appropriate thread!
Don't know why he'd post here!?
BTW, looks good but check where you post before posting! :-)
  #123
Old 10-20-2020, 01:31 PM
Luke Martin's Avatar
Thanks for sharing that, I understand what you mean now !
  #124
Old 10-20-2020, 01:35 PM
Originally Posted by sgtm7
This is the one I got: https://www.amazon.ae/gp/product/B07...?ie=UTF8&psc=1
This is how it looks in my car. The display is configurable to display what you want to see.
Thanks I totally get what you mean't now... Great idea also and thanks for the link, appreciate that
  #125
Old 10-20-2020, 01:41 PM
Wow. That really looks good, I was trying to think of what would modernise and match my cream interior and this certainly does look impressive... You did an amazing job too of wrapping the parts, I'm sure that wasn't too easy to do either... Great Job !! Thanks for sharing...
  #126
Old 10-20-2020, 01:57 PM
fxdwg's Avatar
Luke,
Since you have a cream interior, here's mine with the factory "lux aluminum weave package" and an ivory/slate interior combination. While I mostly like it, it's definitely an unusual combination.
  #127
Old 10-20-2020, 02:47 PM
peterv8's Avatar
Thought this thread was about stereo upgrade!?
Make a new thread about interiors.
Threads become so big/long if we start discussing everything else here.
DGL (10-20-2020)
  #128
Old 10-20-2020, 03:17 PM
Sean W's Avatar
Received 4,219 Likes on 2,367 Posts
I think it's relevant to Luke's post #103 but yes, it might have been better to point him to a link instead.
  #129
Old 10-21-2020, 12:49 AM
peterv8's Avatar
delete
  #130
Old 10-22-2020, 03:58 AM
Apologies , better to stick to the stereo related stuff .. My bad !
The following 2 users liked this post by Luke Martin:
peterv8 (10-22-2020), Sean W (10-22-2020)
  #131
Old 10-23-2020, 06:09 AM
peterv8's Avatar
So Luke, how happy are you after a few weeks with the unit? Found any more glitches or misspellings? Is the touchscreen good and responsive?
  #132
Old 10-25-2020, 03:27 AM
No complaints at all .... very glad I did the upgrade and no regrets .. it’s stable , works well
peterv8 (10-25-2020)
  #133
Old 10-25-2020, 11:01 AM
Sean W's Avatar
Can you make the OEM (temp etc) controls larger on the screen or are they permanently fixed to that size?
  #134
Old 10-26-2020, 09:46 AM
DGL's Avatar
DGL
DGL is offline
The ability to extinguish error or fault codes such as low tire pressure etc from the instrument cluster display will be lost with the conversion. With the OEM infotainment system the instrument cluster display can be made normal by removing the fault message. This could be frustrating for some owners dealing with persistent fault messages.
The following 2 users liked this post by DGL:
Cee Jay (10-26-2020), ralphwg (10-26-2020)
  #135
Old 10-26-2020, 09:55 AM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
Would you be able to clear those fault messages with an inexpensive OBDII ELM327 DTC reader and the free Torque app? If so, that's a cheap and easy work-around.
  #136
Old 10-26-2020, 10:45 AM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
THIS would be a deal-breaker. At least until I get around to disabling my TPMS.
Course, low key battery would also do this, and a few other things I have seen.
I don't think clearing codes with an ELM would remove the TPMS error from the dash though. Nor a Low Battery warning.
Stuart S (10-26-2020)
  #137
Old 10-26-2020, 01:47 PM
jahummer's Avatar
Received 2,367 Likes on 1,482 Posts
Some solutions to those problems...
disable TPMS with SDD and replace the fob battery when it tells you to - it’s not just there to annoy you or prompt
you to make it go away each time it reminds you
The following 2 users liked this post by jahummer:
carealtor (10-27-2020), sgtm7 (11-04-2020)
  #138
Old 11-05-2020, 09:20 AM
peterv8's Avatar
Wonder if Ceejay is right from the beginning!?
It is strange that Luke is totally gone, no interest at all in this forum so why post only the unit and then be gone? He showed a picture of the airco buttons and it was on recycling and the heatet steering wheel is on while you see at the top of the screen it's 34 degrees celcius outside!? Also, why are there 2 places on the unit to adjust fan speed? I've been checking Aliexpress and they don't sell many and only a couple of reviews where one writes "It works! And for a very reasonable price. It fits perfectly with my Smart Car. I installed it myself, the process is simple. You just match the wires and most are color-coded." this is written by a US buyer!?
I'm not convinced and won't be buying one just yet. It's to much money for me to spend on a unit that might not work as well as the video and Luke shows.
The following 3 users liked this post by peterv8:
Cee Jay (11-05-2020), guy (11-05-2020), ralphwg (11-05-2020)
  #139
Old 11-05-2020, 09:42 AM
Cee Jay's Avatar
Old 11-05-2020, 09:59 AM
jahummer's Avatar
He hasn't been active since the 25th of October although that doesn't really mean much. I reckon if he doesn't return or has little input regarding this product then suspicions may be correct. But it doesn't matter really. I think everything there is to know has already been discovered and I would expect no further updates or changes to the product. The X150 is a very, very small market, these companies already offer the same type of product for numerous other marques, particularly ones with a greater presence and better aftermarket demand.
The following 3 users liked this post by jahummer:
Bill Mack (11-05-2020), ralphwg (11-05-2020), Stuart S (11-05-2020)
Quick Reply: Stereo Upgrade for XKR 2007
