Sticky Buttons console and steering wheel 2014 xk
Sticky buttons on the Steering wheel and console are getting worse over time.
I am aware of the faulty material used and the various cleaning methods arrempted. None seem to be the correct solution and I'm considering changing the audio/telephone buttons and the speed/cruise buttons on the steering wheel first.
Has anyone done this procedure?
Does the airbag have to be removed first?
Do the controls simply pry out then push and click in place once the electrical connects are made up?
Any tips?
Any tips?
Sticky to the touch. The button function is fine. The coating applied to these buttons and their surrounds to make them "soft touch" breaks down over time and heat makes them worse. They become very gummy and attract dust that is very difficult to remove.
Several people have tried to remove the coating but in my opinion it just makes the coating softer and gummier. Some have scratched the top coat down to the hard plastic but it gives a different appearance.
This has been a problem on several luxury vehicles. I had a Maserati with the same problem. I believe Ferrari and a few other cars have a similar problem.
I believe it started with 2010 models. It is not unique to our XKs. Several threads about this problem throughout this forum with other Jaguar models particularly in warm states.
As I recall, Jaguar issued a TSB concerning this issue at one point.
Any tips?
Any tips?
So far my 2012 has not had this problem. I am wondering if this is climate related as here in the NE we do not get continued high temps and humidity. I also don't use the car daily and it stays in the garage when not in use. So those who have this problem do you think it is climate related or that it will happen to all .
I have a MY’11 XK without any issue.
However, not so with MY’13 XJ. I do live in the Desert Southwest and would contend that heat (not sun as both cars are well protected from sun exposure) has been a significant contributor to my issue.
This last summer (where the XJ mostly sat plugged in and covered in a hot garage) seemed to have “done them in”.
Good news (for me) is that I have a couple months left on my XJ warranty and all indications are that Jaguar will be replacing my switchgear under warranty. It goes in to the dealer on Monday for assessment and parts determination.
