Still thinking about 2010 XK
Hello,
First thank you for all the great info and answers.
Tomorrow we're taking the car for PPI.
Spoke to another mechanic, and he mentioned about the water pump issue, (the water pump was replaced in the first 5K miles, now it has 46K) but not only that but also all the hoses that are connected that can fail. Anyway to keep an eye on that before this happens?
Also regarding the oil level, he mentioned that sometimes the sensor goes out and you cannot tell if there is no oil. Any way around that since there is no dipstick?
Thanks again to all in advance.
oo zone
oo zone
Regarding the oil level. It is checked electronically. Cycle through the trip computer with the engine shut down for several minutes (7-10) after the car has been driven for at least 10 to 15 minutes. The sixth click on the button that cycles the trip computer which is on the end of the turn signal stalk will take you to the oil level indicator. The indicator will show you whether you are in need of additional oil or not. There is no way to check the oil pressure. If you want to check the alternator and the coolant temperature buy an OBD reader which can be purchased either on EBay or Amazon for $15-$25 and buy the Torque app for either the I-phone or Android phone and you will be able to setup many measurements as well as a fault reader.
Know that these cars normal temp is between 185-210 degrees Fahrenheit and the volt reader should be between 11.5 and 14 volts depending on speed and whether or not the accelerator is being pressed. By the way there are several threads dealing with the water pump issue; one of them has the current pn for the pump if you want to check the pump in the car. Hope the rest of the PPI works out.
oo zone (12-03-2019)
Hello,
oo zone
oo zone
If your PPI smells coolant, get the pump replaced again.
as far as hoses, mine were all replaced wit the pump replacement. Hopefully yours were also.
good luck! Keep us posted.
oo zone (12-12-2019)
As mentioned, the water pump will fail shortly, the dash leather will separate from the dash, if you have a leather headliner, that will come loose also. Diffs will make weird shuddering noises on left hand turns. Timing chain tensioners will probably fail, supercharger couplings will get noisy and might start eating into the shaft. TPMS sensors will go berserk, The AC might not blow cold air from start up and be incapable of clearing the windshield on rainy days. Coolant hose underneath the supercharger will fail along with many others that are made of plastic. Apart from that you should be fine
The failures I listed are all common and very well documented. You know I don't have numbers just the same as I know you don't have numbers. I am not sure why you even asked. Jagtoes, you have been on the forum for long enough to know that these are all common failures on the XK.
Sad but very true.
Sad but very true.
The only thing on this list that I've experienced in almost 70,000 miles and ten years is the TPMS sensor deal. I still don't have that worked out and the only part left to change is the receiver module. I had my original water pump checked and there is zero seepage, zero rattle. One of my fuel injectors failed, while that isn't super-common, it is pricey to repair.
Sad but very true.
Sad but very true.
And remember, a lot of people only come to forums because they have a problem they want advice on. I frequent this forum to learn but I am also a member of a GMC forum, a Nissan forum and a Hyundai forum that I only go to when I have a problem.
I know about 15 people with X150s that are not on this forum. The only issue I would say is common between them is the water pump. And one of those water pump failures was on a 4.2L @70k miles, and that's pretty much unheard of, right??![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
People at proctologists office tend to be the ones who have problems.
Mind you some hypochondriacs will write a post-dated check and have the doc dig around for 30 mins to no avail.
The battery powers the car. This car has been engineered to suck that power away more quickly than others due to all the control modules / electronics etc. (Exercise that round thing above your shoulders a little more often.)
Received 2,646 Likes
Do you mean the 1000 watt stereo, that wont power on if you are low on power or while cranking, and turn off automatically when battery is low.
What could they have done differently?
OK great and we can start the data base with you. So you are 1 of approx. 54,000 X150 cars with these issues. Let the count begin.
