Still thinking about 2010 XK
#41
Now the OP is aware of the potential frailties of the XK, he is better armed to make a wise decision on the purchase of his potential new car. He knows a little more of what to look out for.
My car has had some of the issues I listed and others I have not. I have owned mine for 2-1/2 years and while it has not been flawless, it has been no worse than the BMW’s, Mercedes, Bentleys, Maseratis and GTR’s that I have owned. I believe telling my experiences, good or bad in cars rather than to claim they are perfect, will never go wrong and leave some guy with a false sense of security.
#42
Hello,
Here is what the ppi said as well as some info from the car fax.
Moisture / coolant around frt coolant manifold. Frt and rear manifolds look original.
What are your thoughts, Would you know approximately how much something like this would cost, and any places that you recommend. I'm in L.A. but no problem driving to O.C.
I'm trying to download the report, but I guess they took a picture of it, and for some reason it's giving me a hard time.
but that's all it said, besides tires have 80%. No codes. Breaks are good. No accidents.
from the car fax:
in 2011, at around 9200 miles, Water pump replaced, power steering hoses replaced.
in 2013, 28K miles instrument cluster reprogrammed, body, computer module reprogrammed, wiring repaired.
2014, Battery replaced.
2015, 41k Miles, ECU replaced again,
Besides that all regular maintenance looks like it was done.
from the car fax:
#43
Hello,
from the car fax:
from the car fax:
Any evidence of coolant anywhere externally means something is leaking. Could be a hose, could be the water pump again. If it was replaced in 2011 it's probably bad again. The most recent pumps are supposed to be better (I suppose we will see) but the pump from 2011 is just as unreliable as the original pump. Get it checked out at a dealer/indie that is familiar with the 5.0L XK. Pump and plastic bits replacement at a dealer will run about $1400. Maybe save a few hundred at an indy. Genuine Jag replacement parts will run between $400-700 depending on where you buy them. My dealer wanted $700 for the parts. I bought from various dealers online and saved about $300 and brought the parts to the dealer to install.
The ECU replacement is a little scary. Especially twice. I don't even want to know how much that would cost out of warranty..... I don't know of any issues related to ECU. Maybe search the forum. It's not common, even here. It would be good to see if you can find out why it failed twice if possible. Probably doubtful though.
oo zone (12-12-2019)
#44
Just saw this on the Audi form I follow because of my kids Audi. This is a reliability issue and if Jaguar has a similar problem then the consumer should persue the same avenue. https://www.audiworld.com/forums/a4-...ranty-2983932/
Queen and Country (12-05-2019)
#45
#46
The memories or nightmares of British Leyland still live on. Pathetic cars made my people who could give a **** and spent most of their days standing outside the plants on strike. (Jaguar was owned by BL) Yes, it was a long time ago but certainly is still a strong memory in my mind. Oh and the QEll is of German descent so I would imagine she would have been a pretty good mechanic. Probably had to be to fix all of her Jaguars!
#47
Received 2,626 Likes
Hello,
from the car fax:
from the car fax:
Have you decided to move forward with the purchase?
#48
I'm going back and forth. I really like the car, just concern if that will be a continuous problem, let's say if I replace the water pump, the outlet pipes and anything that has to do with the cooling system, will it be okay for a few years?
It looks like you are in Newport Beach, anyone there you recommend to work on the car that's honest and reasonable?
#49
#50
You might want to look on Yelp or Facebook to see what others think of the shops.
#51
I just had a local Jag service department replace my water pump. I was reluctant for months. I purchased my 2010 XKR with 29k on the odometer. it currently has 33K. The whole time I owned it i would occasionally smell antifreeze after a drive. There were no signs of leaking coolant. I could not identify anything with my scope. But, after 4K miles I had lost about 1/2" of coolant loss from the coolant reservoir. So, it doesn't take a rocket scientist to know there was an issue somewhere. I knew it was not an internal consumption issue because I had an engine oil analysis done. Total cost of the repair was less than $900. Which was a shock to me, as I expected at least $1,200 - 1,400. At any rate, i am glad I had it replaced. Only other issue is my TPMS sensors are starting to go out. But, that should come as no surprise because the batteries in them are at least 9 years old. Other than the rear window separating from the fabric, I have had no issues.
#52
oo zone, you didn't mention if it was a coupe or a vert I don't think, or why you're looking at this particular car you mention. There's an 08XKR Portfolio convertible in Clovis posted in the classifieds here with 40,000 miles. You seem to be on the fence with the 5.0 liter, so just asking what's driving your interest in this particular car if you don't mind?
#53
The following 2 users liked this post by bocatrip:
Cee Jay (12-08-2019),
Queen and Country (12-12-2019)
#54
#56
#57
It is not for me to engineer a car built by Jaguar. The fact that a battery tender is required, and the owner needs to lock, and/or double lock the car to prevent battery drain are engineering issues. As are control modules that have a constant drain on the system for a length of time after the car is shut off.
My luck with batteries seems to go in two directions. When my battery is put in a Jaguar XKR is seems my luck is all bad. Yet when I put a battery in any other make of car, I seem to get a good one. Go figure!
#58
#59
#60
I surmise that as most posts on fora such as this deal with problems and whinges it is easy to get a very skewed impression of the breed. I took my 2005 XK8 to 111K miles and other than a burst octopus pipe at the rear of the engine and a sticky serpentine belt tensioner (both easily and cheaply rectified) she was one of the most reliable cars of the quite a few I have had over the decades.
