Strange noise above left rear wheel.
hmmm, somewhat baffled.
I noticed that a strange noise has appeared in my left rear wheel arch. It goes aways after about 20 sec, but reappear if I start driving.. Any ideas ?
Taking it to the dealer next week.
Noise is also audible in the rear trunk.
Petrol pump? Suspension? Need to change my battery?
Any input much appreciated...
https://www.youtube.com/watch?v=SsVO...ature=youtu.be
I have noticed that I can make the noise appear if I rev the engine, at idle it goes away after 15 sec and not not reappear until I press the accelerator again. This then leads me to believe that it must have something to do with the vacuum system that is related to the original exhaust valve... Only thing is that I have an aftermarkt exhaust fitted, so perhaps the mechanic did not do a proper job of sealing the hose/valve ect... Anyway my two cents, and hope to get confirmation tomorrow when my mechanic will have a look...
Think you could be on to something.
I have noticed that I can make the noise appear if I rev the engine, at idle it goes away after 15 sec and not not reappear until I press the accelerator again. This then leads me to believe that it must have something to do with the vacuum system that is related to the original exhaust valve... Only thing is that I have an aftermarkt exhaust fitted, so perhaps the mechanic did not do a proper job of sealing the hose/valve ect... Anyway my two cents, and hope to get confirmation tomorrow when my mechanic will have a look...![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
A quick check would be to remove the pump fuse (the infamous fuse 19 behind the centre back seat) and deactivate the pump completely?
Anyways, good luck!
Stormdk (04-13-2014)
I love this forum ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Thank you very much ejjbee... Cant beleive that I did not think of that my self (fuse 19).
It did the trick. nice and quit now.
EJJBEE, You saved me a bundle, and I now owe you a couple of beers or a bottle of fine wine, let me know if you ever in Copenhagen (Denmark) or Malmö (southern Sweden) ...![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
PS. quit difficult to remove the cover for the fuse box, and looking in the manual did not provide much help, nearly ripped the whole dam thing appart..
ejjbee (04-13-2014)
hunter34
19
09-14-2022 11:09 PM
innzane
09-02-2015 10:08 AM
