Strong fuel smell (sometimes)
My 08 xkr occasionally to frequently gives me a strong fuel smell when running. It's not all the time which I would attribute to a leak, but when it does it is bad.
I can really smell it in the front wheel wells but not so much under the bonnet. I've already pulled the rear panel of the front fender liners hoping to find evap equipment (nope) and an obvious problem, but no joy yet. I also replaced the rubber seal from the intake T to the throttle body as it was pretty mangled, and for 24 hours it didn't stink - but now it does again.
So who here has resolved a similar issue?
Gasoline is highly volatile and the vapors are explosive, so don't delay finding the cause and fixing it. Gasoline evaporates very quickly, so a small leak can make a big stink with no visible signs of a leak.
For possible causes, see:
https://www.jaguarforums.com/forum/x...esolved-70908/
https://www.jaguarforums.com/forum/x...ell-car-92518/
https://www.jaguarforums.com/forum/x...t-days-208467/
If you smell gas, know that you're driving a bomb. Those vapors are like a Molotov cocktail on wheels. All it takes is a spark.
guy (12-30-2021)
