Stuck lid on center console
Guys
I have this latch problem on my 2007 XK. Any detailed remedy will be appreciated.
https://www.jaguarforum.com/threads/...jammed.130223/
You COULD have copied that text instead of posting a link. That made it the most troublesome way to see words.
Anyway, try leaving the cover over the cupholders, pull up on the latch a bit more, but pull rearwards a bit also. Then give the whole thing a firm tug up while slightly pushing the cover forward.
Received 1,975 Likes
Guys
I noted that you're in Arizona. Do you realize that the link you posted is for the UK Jaguar Forum? The UK forum is singular (JaguarForum.com); the US forum is plural (JaguarForums.com). The above are not clickable links.
Below are links to solutions to X150 center console problems from this Forum:
Lid doesn't slide
https://www.jaguarforums.com/forum/x...le-lid-242360/
Lid slides but doesn't open
https://www.jaguarforums.com/forum/x...-stuck-201013/
Hope this helps you fix yours. Good luck!
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
Stuart
The following 2 users liked this post by kj07xk:
ralphwg (02-04-2024),
VroomForTwo (01-29-2024)
[QUOTE=kj07xk;2716568]
I wasn't referring to the OP's link. I was referring to what I wrote in that paragraph, which is in parentheses and looks like a link.
kj07xk (01-29-2024)
Stuart S (01-29-2024)
phoretwan
01-22-2024 05:11 AM
Gary Bokelmann
06-04-2017 12:38 PM
