Stuck In Park
Stuck In Park
2007 XK Coupe....Hopefully there's an easy solution. Gear shift lever is stuck in park, When convenience lites are on, the car is actually in Reverse. The Back assist screen and back up lite is on. if there's no easy fix...is there at least a hidden handle or something to move the shifter to neutral? thank you!...........richard
The rip cord is only available on the 5 litre cars and the OP has a 4.2L.
I don't believe that there is a way to override it on a 4.2L but if the car thinks it is in reverse when it is in park then it sounds like something in the gear lever linkage has come loose.
Received 1,975 Likes
If I remember from when I took my center console out (to fix the sliding ash tray cover), the transmission position cable is behind the carpeted panel on the right side of the console.
Pull the carpeted panel off and then you can adjust the cable.
The service manual in the stickies at the top of this forum will have instructions on removal of that panel (probably in the removal steps for the center console). May even have adjustment steps for the shifter.
However, that’s not the OPs issue. His shifter is the ‘P’ position, but the car thinks it’s in ‘R’.
So I think the cable from the shifter to the transmission needs adjustment (as I said above), or something in the shifter or transmission broke?
barnsie (09-25-2020)
OK, fair enough. It's strange though why Jaguar would design that feature out when transitioning the same engine and gearbox from the XJ series to the early X150 series. My car's gearbox, J-shift etc looks exactly like the one on the picture, so it begs the question as to why they would remove a useful feature like that. I wonder if anyone knows?
Can’t just hop into an open top convertible, pop the trans into neutral, and then just push or tow it away.
Although, they seem to have made it easier with the 5.0 cars, give them a nice cord to pull.
Actually, I am talking out of my a$$. My XK gearshift does NOT look like the one in the video - it has the Sport mode to the left and nothing else. I am thinking of the shift in my X-Type which looks like the one in the video, but of course my X-Type doesn't have a 4.2 Litre V8 in it (unfortunately).
<brainfart mode = OFF>
So here's what ended up being the problem!. I read on line about a guy who had the exact same issue. he said he got underneath the car and there is a bracket that holds the selector cable. The bracket is mounted to the transmission with two bolts. He was missing both bolts. I was missing one!...The cable gets bound up on an angle. When we reached up and pulled the cable / bracket down to where its supposed to be, it worked as it should. So i got two new bolts and a little Lock tight and thats it!..Fixed!...Hope this helps someone in the future that might have the same issue, and really want to thank you guys that gave their ideas, trying to help me!.................r
Great that you returned with your solution to help the next person with this issue
Glad it was accessible to allow a DIY fix, if you do get the chance could you take a pic of the offending bracket and screws?
Thanks again, now to work out if the same arrangement is common in the 5.0 as it is in the 4.2.
sov211 (10-01-2020)
2007 XK shifter stuck in reverse
gkubrak (07-22-2021)
snooktarpon
20
02-17-2021 08:27 AM
Rlover
03-30-2016 10:04 PM
Jaguarpains
12-17-2012 07:53 PM
