Stuck in Sport Mode
My (new to me) 2008 XKR seems to be stuck in the Sport Mode. I don't seem to remember the gear changes being so quick and positive when I first started driving the car after I first got it a couple weeks ago... As I began to experiment with the controls a bit, I quite naturally needed to experience the sport mode driving difference.
Since then, I seem to think the car is still in the Sport Mode. Without my having to slide the gear lever to the left, into the Sport slot, I can still use the paddle shifters as if it were selected to do so. Is this a normal occurrence?
What re-sets the sport mode setting? Is there a switch that has malfunctioned??
Received 1,974 Likes
The paddles work in both D and S, that's normal. If in D and you pull a paddle, you'll see gear numbers appear in the display between the speedo and tach. It will automatically return to normal D mode after a few seconds of non-paddle use, or you can pull on both paddles at the same time, or flick the shifter over to S and then back to D.
If you car truly is in sports mode it should rev match as it changes down gears under heavy braking. It doesn't do that in D.
I also find if I move the gear lever from D to sport the revs will rise so that might be another clue for you.
The transmission is also adaptive so if you have only had it a few weeks it will be adapting to your driving. If I reset the transmission module adaptation on my 07 XKR it seems to change down at the slightest touch of the accelerator pedal but than becomes less responsive the more I drive it probably because most of my driving is city driving.
Can you explain how to reset the sport mode setting? I find that when driving hard in sport mode tranny not shifting and revs super high 7k RPM, before letting off gas. I understand that letting off the gas will shift, but seams not aways doing that... another thing is the Rev limiter (black button), when is that supposed to limit the revs? Doesn't seam to work on my car, when using in sport mode. Thanks
black button?
So the car leans how you drive in about 30 minutes.. so if you start the car and go full throttle, it assumes you are a sporty driver and shifts later on up and earlier on down for a more sporty feel.. if you are easy and relaxed, the shifts are more gradual and relaxed too..
So.. just drive relaxed for around 10-15 minutes.. easy on the pedal and you will notice the car relaxing too..
Firecat17:
A simple question: do you not have the owner's manual for your car? Your concerns are fully explained there...you'll be amazed at what you can learn about the operation and features of your XK - giving this kind of information is the whole point of owners' manuals.
And the more you learn about the XK and the more you drive it, the more you will love it.
Gents...
Thank you for all the feedback and good info you've all shared. I may have jumped the gun on posing my question. I'm guessing the transmission isn't really locked into the Sport Mode, as I may have thought. Rather I guess it is learning my driving style, as was suggested. I think what has thrown me, if you will, is that the shift point from 1st to 2nd is very early on when feathering away from a stop, and the shift seemed to be quite positive. That said, the shift point just seemed a bit low and harsh. I guess maybe not, after all, and maybe it's just the design I am in need of getting used to...
I have driven a BMW M3 whose transmission functions relatively the same, yet different. Our 2015 XF 3.0 Portfolio has the same basic transmission, albeit an 8-speed, and though I seldom use the paddle shifters while in sport mode, I'm very familiar with the adaptive nature of its makeup. The XKR does rev on downshifting, as was stated earlier on, which is what I came to be used to in the M3.
I do have the owner's manual and I have been reading it regularly. There's certainly more to learn and I've got nothing but time to do so. I love the car and will be replacing the brakes and fitting new tires fairly soon. Those changes will make it a true wonder to drive.
It's good to see others have benefitted by my posing the question. Thanks again.
Firecat17,
Because the XF has the 8spd and not the 6 the shifts have less rpm differences and therefore don't feel the same. I also find on my 2010 that sometimes in sport mode (and I always keep it in sport mode and use the paddles), I will let off slightly on the gas to initiate an upshift just to not enter the high rpm mode. And remember, outside of sport mode, the trans starts in 2nd gear so the transition is smoother. In sport mode starting in 1st, it wants to shift pretty early.
The only time it will ever pull away in 2nd is if you have been using the flappy paddles and come to a halt without manually selecting 1st.
So I have experimented around town and highway with my 2014 XKR 5.0L in dynamic and Sport for a week.
Around town, Sport with Flags and downshifts are a thrill.
Car never shifts into 1st. Unless I make it.
Highway S without having to shift, just S not dynamic/flags, and i was wrong, she flew from 65 to xxx mph in a couple blinks, (if I were blinking, my eyes were WIDE open. Sweet. Smoothe. Less 6 cylinder feeling as in, wait for it, wait for it, BOOM.... just fast right away. Fun.
D on highway with flags and you do get that slight delay but then take off. More head jerking quick than the smooth fast auto S mode.
Now all I do every time i take her out is wonder what mode today.... kinda like a wife, what moood will she be in.
MarkyUK (06-07-2020)
It will if you don't use the paddles and just leave it in auto mode. There is no easy way of telling that though unless you count the gear changes or monitor it using SDD. I did the latter so I know it does use 1st gear when stationary and in non flappy paddle mode.
The following 3 users liked this post by u102768:
