Sudden massive oil leak....
Driving home, doing about 70, the car suddenly lost all its oil, I pulled over straight away and turned the car off. I put some more oil in and it came straight out. The oil was coming out towards the back of the sump, rear of the engine. Got it towed home and now need to figure out where it is coming from. It’s the 4.2 sc. Any suggestions on where to start looking?
Received 6,339 Likes
Based on his earlier posts, I suspect he has a 4.2L SC XF.
https://www.jaguarforums.com/forum/w...d.php?t=233242
I put in the post that it was the 4.2l but didn’t want to put XF as hardly anyone has the SV8 XF, so normally get more responses on engine queries from the xkr folk
no hole in the sump. I didn’t get it home till it was dark and couldn’t see anything obvious with a torch. There is oil everywhere so hard to tell. I’m going to clean it tomorrow, put some more oil in and try to pinpoint where it is coming from. I’m thinking it must be a hose that has gone. I just wondered if there was anyone that had had similar problems and knew likely things to check
