Sudden, and surprising, CEL today at work!!
So headed out to lunch after letting the car warm up 10 min or so (s'cold here), and CEL blew up in my face!! Noooo!!!
Anyways so whipped into an AutoZone, just one code came back, P0077, Bank 1 VVT Actuator or some such.
Read in another thread here that low batt voltage is the source for a lot of issues, especially where CELs are involved. So I will check batt first thing when I get home. May very well be original to the car. But certainly open to any ideas, or input or any one with experience with this particular code.
Should add that car is running seemingly normally. Even attempted an Italian tune up on the way back to work. CEL remains. Runs great actually, even got lil squirrelly when I punched it 😁
Thanks!!
Thanks!!
Your post and signature gives no indication as to the age of your car...mines a 2014 and needed a new battery.
So you suspect the original battery, do you keep it on a maintainer like a CTEK?
So help us ro help you!
Google throws up
https://forums.jag-lovers.com/t/random-p0077-dtc-bank-1-vvt-actuator-2007-xkr/371597
But feel sure you'd habe already checked that.
Google throws up
Google throws up
https://forums.jag-lovers.com/t/rand...007-xkr/371597
Google throws up
But to specify, its a 2008 Jaguar XKR Portfolio with 51,183 miles.
I do have a CTek, but car is daily driven so have not really plugged it in, or used much...so its relegated to motorcycle battery maintenance duties.
My first thought was to come here, neglecting a Google search. Reckoned why not come straight to the source where a Google search likely would have led anyways. After a search regarding aforementioned code yielded no results, I opted to post for information and education, and maybe help others in the future who have this code come up.
Google throws up
Google throws up
So I will check battery first, try to clean connector. If light persists, guess I'm ordering, then installing,
an actuator lol
The following 2 users liked this post by Bill Mack:
peterv8 (01-05-2021),
Scott in PA (01-05-2021)
Received 2,646 Likes
Kuekuatsu07 (02-08-2021)
I was going by what code/def the OBDII scanner gave. Although I will double check to be certian. Was writing from memory.
Side note, battery is a NAPA AGM unit from Jan2015. Will be first place I start.
Perhaps 'Presidential impeachment' might be more appropriate.
Typically Europeans know how to ask questions in a more intelligent way,
Taken from an American IT forum
How To Ask Questions The Smart Way
Simlly put, if your asking for help, why not provide the full and pertinent facts up front as opposed to it being prised from your digits?
....or maybe it's just we lack basic manners and politeness lol
Still, the fault is mine for forgetting to add all the details. I see you Europeans are easily confused and need specifics and direction lol Why you must have thought I was posting in the X150 section of jaguarforums about my '88 Tercel, and for that I apologize 😁
At any rate, details were added and I recieved some valuable information to get me started. Will try to post updates until issue is resolved.
Speaking of updates...
..I got a multimeter on the battery, and going by a table posted by a user elsewhere on the forum, my battery is indeed on the low end. Between 50 and 75% measuring 12.31V at the posts, ign off, with smart key and hatch open.
May not remedy the original issue, but definitely something I may look to replace.
There were at least 5 different types of engines fitted to X150s so it does help to be more specific when asking an engine related question
MoparDude (01-07-2021)
The following 2 users liked this post by u102768:
MoparDude (01-07-2021),
steve_k_xk (01-06-2021)
