Supercharger belt failed again 5.0 Xkr Bad pulley install?
Failed belt only a day after install. What you guys think ? Shitty install job ?
https://youtu.be/c75Q5MO9uI0
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
Received 3,259 Likes
Possibly a smaller diameter pulley.
Coz to the best of my knowledge all factory pulleys on the AJ133SC have/had black ribs, not orange like that one.
So I'm going with "shitty install job" - the pulley wobbles enough to throw the belt.
guy (07-31-2020)
That looks like a non-standard / aftermarket pulley to me.
__________________
agreed. Looks out of alignment to me as well. Oddly too Alex, and this might just be the camera perspective, but to me the grooves on the orange pulley look larger than the idler pulley.
I told the customer to take it back to the Jaguar shop that did the work as it's not something that I want to tackle , especially with the pulley in such banged up condition. The shop could also have damaged the thread on the snout end which would make pulley install with the press impossible.
As to out of alignment perspective, The camera does play tricks a little bit cuz I don't think it appears that much out of alignment in real life. To my eyes it just looked a little bit off and not on all the way, when the belt was installed it was not that noticeable. I know at least on the 4.2 cars , when after market pulley is on properly the end of the pulley meets the snout rod which wasnt the case here
Sean W (07-30-2020)
This photo is from and eBay listing for a pulley on 5.0 car and groves sure look different than whats on the car
__________________
The the shop that did the install is really shady and will not give out that information.
__________________
rocklandjag
02-25-2015 04:45 PM
JagTheRipper
11-12-2011 04:28 AM
bloweraddict
07-26-2010 10:44 AM
