Supercharger coolant hoses
I'm having a very slight oil leak repaired on the timing cover.
Seeing as they need to pull everything off the get at it, supercharger coolant hoses came to mind after a member mentioned doing and recommending replacement.
I can see plainly the top hoses, but I got the impression that there was some hosing under the supercharger (I may have misunderstood the members post).
I did a search and there was a post about "dreaded valley hoses" in the x100 forum - but I'm still not clear on this.
https://www.jaguarforums.com/forum/x...on-fix-201288/
I looked through the X150 service manual but was not able to find much in this regard.
Any ideas on this folks?
Mac.
2009 XKR
Mac.
2009 XKR
Curious why they'd want to pull the blower to access the timing cover? I don't think it needs pulled to do the work. I was able to do the water pump with the blower in place and it wasn't horrible, just way back in a hole.
There is one hose that runs back to the throttle body which is a PITA and the blower needs pulled to do it.
The oil leak they are doing under a warranty (around $2000) so I will be getting charged for the valley hose replacement.
Problem is the service manager wasn't sure which hoses are needed to order them - I've looked in the service manual but didn't find the hoses in question - that's why I posted the thread/request.
Received 2,675 Likes
Sean W (06-06-2018)
Sean W (06-06-2018)
