Supercharger pulley 08 XKR 1.5lb and no tune users please chime in
I have searched the forums but cant find enough info to decide if a 1.5lb pulley without a tune worth the hassle, reliability sacrifice vs hp gain. Hoping for a modest low end power gain without much reliability sacrifice. Contemplating EuroToys Pulley. I do not want to go with higher boost pulley for reliability issues.
I had the 1.5lb pulley put on my '07 XKR about a year ago. The car has had nothing else done to it and the difference is noticeable. The pickup from low revs is much better but the main issue I have now is that the right rear wheel is much more prone to wheel spinning so I don't think that it is worth doing anything else to the car without fitting a limited slip diff.
Im contemplating either Eurotoys 1.5lb or Mina galery aluminum pulley but i think mina only has 2lb no 1.5
I bought mine from PowerHouse in the UK and got the guy who service my car to install it.
I think this is the one:
Jaguar XJR XKR S-Type R Supercharger Top Upper Pulley 6% Upgrade stainless steel | eBay
You need a pulley puller, Eurotoys has one for rent
Upper Supercharger Pulley Remover/Installer Tool 4.0/4.2L (Rent), Eurotoys,Ltd.
https://www.jaguarforums.com/forum/x...lation-125704/
It is that simple when you use the puller. The only other way is to cut it off, but that is a lot of work and you risk damaging the supercharger.
https://www.google.com/url?sa=t&rct=...3negL55kY_5aHg
AlexJag (05-24-2016)
Did you watch the video I posted above? The hood does not need to be removed, though you could if you wanted to. Obviously you have to remove the belt. As you can see in the video, the easiest way is to use the puller to remove the pulley, heat up the new pulley so it expands and slides on more easily, use welding gloves to put it on, let it cool and replace the belt and you are done!
although the video shows a car with a different engine configuration, intake and cooling piping is different on the XKR and Im still not sure how to get around the hood without taking it off, its just not very accessible there
They are all basically the same. I did mine with no issues and did not remove the hood. It is as easy as I described above when you have the puller and plenty of room to do it. If you are not comfortable doing it your self, I'd recommend finding a reputable mechanic or service center to do it for you.
harvest14
32
08-21-2016 06:20 PM
NCJagman
05-20-2016 02:17 PM
