Suspension hip-hop
Suspension hip-hop
I have a 2014 XK convertible. The suspension seems to jiggle about a bit (like small bumps in the road) which don't exist. I had all new tyres fitted and wheels balance and it seems a little better but still has a lumpy feel. The wheels all seemed true on the balance machine. Alignment was alsoo checked and adjsuted to spec except rear camber which they said couldn't be adjusted and was only marginally out. The suspension bushings all seem to be good - only on a quick inspection. I would like to eliminate the problem if possible - any ideas? The car has 20" wheels but the probelm doesn't seem to relate to feeling bumps, it happens even on very smooth road and at low speed as well as high.
Mine tends to follow worn surfaces, I don't feel any play in the steering. I just assume the wide tires are following road wear from all the traffic. I had a land cruiser with really wide tires that did the same - shop could never find any issues, they said most likely the wide tires following road wear.
I’m pretty sure it’s not engine mounts. I have run along very flat downhill in neutral at the “bumping” is still there. I also tried what I saw in one of the forums - lift the bonnet engage drive with the brake on and watch for movement- it seemed OK. I did wonder about trying freewheeling with the engine off to rule out misfiring but I don’t think it can be done without the steering lock going on.
McJag222 (02-13-2023)
Neil Stewart (02-15-2023)
thanks Guy, the dealer checked all bushings and said they were good. They also said they couldn’t detect anything unusual- so perhaps I am just expecting a smooth ride which the car can’t deliver. Will investigate more in the spring with alternate wheels.
SebastianV
06-13-2013 08:45 AM
