System Faults, No Start 2007 XKR
#41
hello dan314.
there are 3 rules about doing any electrical work on a jaguar.
1. disconnect the battery
2. disconnect the battery
3. disconnect the battery.
you do not have to remove both cables on the battery -- just the negative, braided cable. then tuck it onto the side or cover with a rag. anything to make sure it doesn't accidentally touch the negative battery terminal.
then, if there is a connector anywhere on the yellow wire, by all means disconnect at that connector AND use electrical tape over any exposed wire or contacts.
then re-connect the battery and see what happens.
if you're nervous about dong this, go to any after market radio shop and give the kid $20
best regards bob g
best regards bob g
#42
hello dan314.
best regards bob g
best regards bob g
The wires are attached by the tightening nut on each battery main terminal connection. Means that I’ll have to loosen both terminal connections to remove the piggyback wires but from what you’ve told me that’s ok (as long as I disconnect the negative terminal first).
#43
Thanks Robert,
#44
#45
#46
‘05 XKR Intermittent No Start
Hey Robert,
Once you told me there are no other connections than main pos and neg cables listed in Jag Tech Docs, I disconnected (neg first) piggyback wires on battery terminals which powered an “add-on” Sirius Radio system. Couldn’t see any obvious shorts (but it’s my opinion after reading hundreds of electrical fault postings in the a Forum that electricity is basically just magic). No faults occurred and she’s cranking great.... so far so good.
Thanks again for your intel.
Dan
Dan
#47
#48
Received 2,048 Likes
#49
No start XKR
Before I discovered / disconnected the ‘add on’ Sirius Radio power leads, I had my ‘05 XKR jump started a couple of times (with AAA boost pack) and suffered no problems at all. Can’t speak to earlier / later models.
#50
kj07xk (12-16-2019)
#51
Well you have another battery coming so time will tell but just know Jaguar recommends you do not use another car to attempt a jump start your car. It can destroy the harness if memory serves. 12.8 volts resting is strong. You can have someone attempt to start the car with the volt meter attached. If the load drops below 9.7 volts, battery is toast. please let us know the outcome Monday.
#52
Yes you shouldn't do it. I'll see if I can find the article. Was an Australian article and Jaguar indicated to the writers that jump starting off another vehicle can damage the engine harness. So use a portable lithium Ion charger or a dead jump as Cee Jay indicates.
Edit:
Here's the article.
https://www.mynrma.com.au/cars-and-d...ot-a-good-idea
Edit:
Here's the article.
#53
#54
from the article:
"Jaguar warned us that you could damage the whole wiring harness if you try to jumpstart one of their cars, and that warning is probably applicable to most vehicles built in the past five years."
It's not just Jaguar. This applies to most all modern cars, certainly on the high end. There are so many viable LI battery pack options now days, there's no reason not to stock one in your boot.
Ultimately when push comes to shove, you gotta do what you gotta do to get up and running.
from the article:
#55
peterv8 (12-16-2019)
#57
I hadn’t heard of the ‘dead jump’ method described by Cee Jay, but its using the donor car as a ‘battery charger’ on the dead car.
Both should get the dead car started. The first will get you going faster, the second might give you some reserve if you happen to shut off the car before you get to your destination to change or fully charge your battery.
#58
Sean W (12-16-2019)
#59
Rahul Satoskar
04-16-2018 09:30 AM
