Tech help required
Old 12-28-2013, 05:31 AM
grisley's Avatar
Default Tech help required
Water leak to drivers footwell on 2009 xk has been traced to leaking gland where the lower steering column goes through the bulkhead.
Before I shop the car I need to know if there are any drains that may be blocked by leaves etc on the engine side or anything else that needs checking that would cause water to gather and in leak into car in this area.
It is NOT air conditioning drains as water can be seen entering through gland.
Old 12-28-2013, 11:51 AM
hawaii's Avatar
What's a Gland?
Old 12-28-2013, 12:07 PM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
That is a $1000 USD job to fix it properly. AC drain design is bad and is a known issue on XK's.
Old 12-28-2013, 12:09 PM
jimbov8's Avatar
A device, such as the outer sleeve of a stuffing box, designed to prevent a fluid from leaking past a moving machine part.
Hope this helps
Old 12-28-2013, 12:45 PM
CleverName's Avatar
He he... One of the more interesting parts of dealing with an international car! Cool terms we don't often hear in the US! "Gland" and "Stuffing Box" are not car terms here!
Anyhow OP, as said earlier, the issues is common and not fun to deal with. Pulling the dash is the correct fix by Jag, but others have been a little more creative if you search for it....
A recent post shows that the water can back up and kill a module under the dash as well, so best to get it fixed...
BOL
Vince
PS the "fix" PDF does not belong to me...
File Type: pdf
File Type: pdf
hawaii (12-30-2013)
jagtoes
04-22-2016 07:37 AM
prettydaim
11-12-2015 08:05 PM
Corycarlo
10-03-2015 09:33 PM
Vector
US Lower Atlantic
09-28-2015 11:08 AM
Quick Reply: Tech help required
