Tell me about your tips
Just got back from a nice 80* day drive. As I put the car to bed and going through my normal ritual I noticed something about my exhaust tips. I ran most of the tip in normal driving and did not open up the outside tips. What I observed as I was wiping down my tips that the right inside one was a little darker then the inside left one. I'm not talking rich dirty just a little darker. Also i notice when the car is idling there seems to be a little more pressure out of the right inside tip then the left. I assume this to be normal but what has others experience been.
Interestingly - just yesterday I stood in the drive and watched my son leave in my XKR. The car had not been driven for a couple days so the exhaust was visible (as it was emitting a bit of vapor). When looking at the back as it drove away the right side exhaust had a noticeable increment more vapor (i.e. exhaust volume or amount of vapor at least was greater vs. left side).
No idea why that would be but I saw it.
I'd be surprised if the XK had independent dual exhaust systems and headers.
Presuming it doesn't (very few cars do..need two cats, balancing back pressure, etc.), exhaust will flow greater out of the path of lower resistance. With pipe routing often slightly different , one exhaust port almost always has lower resistance.
Higher volume = higher deposits in the tips.
I personally haven't looked that closely to see if mine has a large or minor color difference. Both are pretty dark on the inside.
mikiep
12-20-2019 07:37 PM
n2audio
17
10-09-2015 10:53 PM
FS[SouthWest]: Adamesh X350 Exhaust Tips
XJ8JR
10-02-2015 12:13 AM
