Temperature warning
I'm aware there is no temperature gauge or even an idiot light. What I don't have a definitive answer to is what if anything should I be expecting on my dash to light up to give me any indication or warning that my car is running hot or worse has overheated? I have no problem at this time but would like to be proactive as what to expect especially when I know how vulnerable our water pumps are on the 5.0 engines.
The car will give you an over-temperature warning.
If you really want to know the temperature of your engine though, hook up an inexpensive OBDII monitor such as the ELM327. This will directly read coolant temperature, and if you use it with a smartphone, you can monitor it while you drive and see the normal fluctuations.
bocatrip (04-27-2014)
Probably not for a very brief period, but it certainly will stress it. The problem with these type of threshold indicators is simply that...it is a threshold...if there is a cooling system fault causing overheating, often there is nothing stopping the temperature from continuing to rise over 247 until you (hopefully quickly) intervene and shut down the engine.
The value of an actual gauge is you might see your car beginning to run hotter than normal before it actually overheats.
There lies the Conundrum.... No gauge. This is a first for me with my career with cars. I hope Jaguar XKs don't have any history of overheating as there's not much I can do. My car doesn't have enough mileage to even change the thermostat for a fresh one after only 6,000 miles. I guess, checking coolant levels periodically couldn't hurt either.
Ngarara (04-28-2014)
Many or most street cars are really not designed for sustained, high RPM track driving, particularly in hot whether. If used such way adding an extra oil cooler is always a great insurance.
It wasn't my car, I'm not that crazy LOL, it was during the Jag R Academy.
The instructors told us not to worry about it as the engineers said there was a bit of headroom left before permanent damage would occur. This was actually one of the conversation I had with Davy Jones as he asked the engineers to up the limit by 5-10 degrees as that would have stopped the constant warnings.
This is also why I brought up extra cooling as my next step, I don't need a blown engine due to over heating at 6500 RPM.
One more STRONG reason to avoid purchasing an ex-Academy Jags
![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Good idea for you to consider the extra cooling. I installed that extra oil cooler in all my cars that I drove hard on the track or, even on the street. My present (street only) RX-7 has only a single oil cooler and when I do a red-line, steep uphill canyon run (about 3 miles) the temps rise alarmingly. If I tracked the car or pushed it further I would have to add that second oil cooler. My previous twin turbo RX-7 that I track raced had dual coolers with no heat issues during even long races.
I was a bit surprised myself but I have no details of the conversation with the engineers either. The cars are driven very hard at the advanced event, I was lapping 2.5 seconds off of Davy's time(yes I'm proud of that LOL) in the same car. I had to turn off the A/C so it wouldn't trigger the warning.
Albert-This is what really got me going on the cooling as it REALLY concerned me. We have oil, air and engine cooling on these cars but just looking over the car airflow through these coolers isn't sufficient. You can ram air in but you also have to let it escape which is where I see the major deficiency.
To sum it up I would not by one of the cars they have been beat hard, very hard.
axr6 (04-28-2014)
XKR being towed to dealer with blown engine... dealer hooks up diagnostics and finds history records for excessive heat, triggered warning light for sustained high RPM periods... they immediately deny warranty coverage for the engine damage... customer argues; "But, But,... the Jaguar engineers told me it was OK to drive with the temp lights on at the track..." unbelievable
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I am still in disbelief about Jaguar people telling participants to ignore the warning lights on the track. I keep seeing the following scenario:
XKR being towed to dealer with blown engine... dealer hooks up diagnostics and finds history records for excessive heat, triggered warning light for sustained high RPM periods... they immediately deny warranty coverage for the engine damage... customer argues; "But, But,... the Jaguar engineers told me it was OK to drive with the temp lights on at the track..." unbelievable![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
goges
10-05-2015 04:53 PM
