Is there anything to do on the battery before plugging a CTEK charger?
Old 01-12-2021, 05:31 AM
GGG is offline
Received 16,852 Likes on 12,186 Posts
Originally Posted by Stuart S
It works, but it's not what the factory recommends. They want you to buy the OEM accessory Battery Charging Kit so they can make more money. .....
I just used the supplied CTEK connector with eyelets to the recommended terminals and added a CTEK extension:
The extension exits from the LH rear vent in the Luggage Compartment. There's tidier and more expensive approaches but this works and it's convenient.
The following 3 users liked this post by GGG:
mosesbotbol (01-12-2021), ralphwg (01-12-2021), Stuart S (01-13-2021)
  #122
Old 01-12-2021, 10:19 AM
mosesbotbol's Avatar
Received 1,202 Likes on 933 Posts
Just like a clergyman, you do it by The Book!
Made the most sense too.
  #123
Old 01-19-2021, 09:58 AM
George Abitbol's Avatar
So finally I gave it a shot last night. I plugged the CTek to my battery via the "connect" cable (left there permanently and bolted on the other end to the battery terminals) in the early evening and left it outside the trunk to begin with. From the LEDs (lit up to 3 only) it said the battery could use a charge... I came back 2.5 hours later and touched the charger: barely warm. So I thought "what the heck" and moved it inside the trunk for the night. Still barely warm this morning...and the LEDs were lit up to 7...much better.
Bill Mack (01-19-2021)
Britrover
01-13-2024 06:23 PM
bjmawg
08-26-2021 07:59 AM
Potvinguy
12-10-2020 10:59 AM
rtcosic
XF (X260)
05-25-2020 01:43 PM
tony bosco
02-13-2015 05:05 PM
Quick Reply: Is there anything to do on the battery before plugging a CTEK charger?
