Third Brake Light Bulbs (2 are out)
LEDs used this way are brightness matched, so even if you were to open the unit and solder in a couple of similar LEDs they will likely look out of place.
If you have the time and inclination, you might be able to crack open the housing and use a cheap commercial LED strip as someone did here on an earlier model XK8 coupe: https://www.jaguarforums.com/forum/x...-repair-27177/ and then reseal the housing with some clear RTV.
Klinsky (06-03-2014)
However if the LEDs are in fact accessible, I would remove a good LED from each end to replace the burnt ones, and then solder in two generic replacements to the ends... This would not stand out as much as different intensities in mid-strand....
my 2 cents
-V
Klinsky (06-04-2014)
rsa760041
23
09-25-2015 01:33 PM
