Tire flat spots?
Old 07-22-2014, 09:05 AM
hdavidson's Avatar
Default Tire flat spots?
I don't drive my XKR-S but once a month, if that. I suspect I'm susceptible to getting flat spots. Is this a genuine concern? Have anyone tried a product like this..?
Amazon.com: Race Ramps RR-FS Flatstopper (Pack of 4): Race Ramps: Automotive Amazon.com: Race Ramps RR-FS Flatstopper (Pack of 4): Race Ramps: Automotive
Old 07-22-2014, 09:10 AM
jimbov8's Avatar
For that kind of money why not make your own out of some hard wood.
When I go to work it is for 2 months at a time, all I do is raise the pressure in the tyres to 45 psi. When I get home, lower the pressure to normal and take for a good spirited drive to warm them up.
Never had a problem yet.
Hope this helps,
Old 07-22-2014, 09:36 AM
ndy.boyd's Avatar
v8cat (07-22-2014)
Old 07-22-2014, 02:56 PM
ddsski's Avatar
Those race ramps should cost ~26.70 dollars each, not $267 each. That's just nuts even if they do work.
Old 07-22-2014, 05:04 PM
axr6's Avatar
What I do on my cars that may not be driven for weeks or months is to put a blue masking tape on each wheel to indicate wheel/tire position and simply push the car forward/backward periodically to change the position of the tires that rests on the ground.
Stuart S (07-22-2014)
Old 07-22-2014, 09:56 PM
Stuart S's Avatar
Received 6,285 Likes on 3,449 Posts
+1 The easiest and most cost-effective way to prevent flat spots.
But you're wasting masking tape - you only need to mark one wheel! If you're worried about the tape falling off in cold weather, then just use chalk to mark the tire.
Anyone who buys that Amazon product has more money than brains! Just my
Stuart
Jandreu
06-30-2022 03:10 PM
weisberg
03-25-2021 05:47 PM
perfectson
11-01-2015 10:46 AM
Armor6
09-14-2015 07:56 PM
Armor6
09-10-2015 12:08 PM
Quick Reply: Tire flat spots?
