Tire Not Monitored
Tire Not Monitored
Hey Folks, 2013 XKR I have 2 faults, (Tire Not Monitored, then Tire Presure System Fault). I have emptied the tire with engine off and on and re filled, Still have the errors. I have not touched the battery cables to reset yet as we know thats a pain. There is some things written on this but seems different. Also, hit cancel on the wheel with no luck. Anyone else solve this 2 fault issue?
Getting back to @RWS1965 original post, Following the battery change, did you take the car for a spin? As per the manual, there is a relearning process for the ECM and TPMS (and TCM) that can be invoked through a proper test drive process.
Also, there are specific TPMS DTCs that should give an indication of the issue.
Cheers.
Cheers.
The VDO ones are not listed for a 2014 in RockAuto. Com. Schrader is a good brand and they are 315 frequency. Is there a difference in the 2013 and 2014?
No answers, just more questions:
I have fought the blinking tire lights for some time.Replaced several sensors and the blinking persists.
Once I find some local with the ability, mine will will be 'deleted'.
Yesterday one tire was indicated followed by the system not monitored warning. This is a new warning for me.
Does that indicate that a tpms sensor battery is dead? or has the system just finally failed?
WJ
WJ
At this point in time will turn off the system before going for 4 new ones again.
Just asking if a totally dead sensor activates the red warning @ tire monitors sensor.
btw...are you going to the texas mile in a couple of weeks?
wj
