Tire pressure monitor issue
A couple of weeks ago, I started getting tire pressure warning messages for the front passenger side tire. I checked the pressure and it was fine, if anything, a couple of p.s.i. high, so I let a couple of pounds out, and the warning disappeared. It re-appeared a couple of times over the past couple weeks, but would almost immediately disappear. Yesterday and today, the warnings have come back and then disappear after a minute or two, but each time it shows a different tire and sometimes two at a time. Again, I checked air pressure and all tires were fine. Has anyone else had any similar experience? Also, I replaced 2 rear tires about three weeks ago, could there be any relationship? Will a hard reset, reset the module? Any help would be appreciated.
It is annoying to see this light blink then go solid. Then there are times when I don't get the warning light for several weeks.
Received 2,012 Likes
There was an earlier thread, where the poster's issue was tracked down to wires from a sensor receiver being poorly routed, such that they were pinched and rubbing on other parts, resulting in a short circuit.
Sounds like maybe you have the same issue? Intermittent shorting out of a sensor receiver?
tberg (08-11-2015)
richzak,
I found some interesting information on the same type of faults and warnings on an earlier set of posts on the XF forum. My problem is described exactly but there seems to be some varying discussion about how to fix. Some said a reflash and computer update fixed the problem, others replaced the TPMS module.
I will take it in and see what the local dealer has to say.
https://www.jaguarforums.com/forum/x...-140440/page2/
richzak,
All I know is, it's annoying.
I have had the same issue off and on for at lest the last year. I have had the dealer look at it multiple times. Now I just live with it. It is extremely annoying. My sequence usually is the following; TPMS not functioning - no tire/wheel identified. then is replaced by a warning for the right front tire/wheel which can stay on anywhere from 1 minute to 30 minutes, then goes away and will come back, tc.,etc., etc. I would just like to unhook the whole thing. But the dealer says that that's impossible because of the various computer interconnections.
funny timing with this thread, I just went though a similar thing with my '15, low tire pressure alert and the actual pressure is fine. The dealer suggested I over-inflate, then let out air to spec, which worked, this time. Can't wait to see what the morning brings! And right, having the alert icon on when you know things are OK is really annoying.
So I just got home (10pm west coast) after a very long day of work, and this is what happened today with the warnings. Left about 8am this morning and drove to downtown L.A. from the valley, about 15 miles and an hour drive in traffic, ABSOLUTELY NO WARNINGS the whole way. I park the car for about 20-25 minutes while I picked something up, got back in the car, started it up, and immediately there is a warning for the right front tire. It went off after a couple of minutes and then came back after about 5 minutes, and then went away. Drove out to Palos Verdes, about another 45 minutes, no warnings. Back to the valley and all over the valley in the afternoon and evening, no warnings. Yesterday, every ten minutes all day long, today twice in the morning and nothing afterwards. Just bizarre!
Similar issue here on my 07 xkr, when I picked up after spooling up some Pirelli's the tire shop indicated that the rear tpm's were going off and it would reset after 50 miles or so. 500 miles later still flashing between the two rears. I told them to only put 29 pounds in the rear tires to improve tire wear and figured the whole time that was why they were popping off. Finally got tired of them flashing so I pumped them up to 33 lbs and after 200 miles so far it is happy. Not trying to hi-jack the thread but can they be reset to accept 29lbs?
I've been having this same problem for about a month now. I checked the wire-pinch bumper area and all was well. I also swapped the front two antennas and the Not Monitored stayed at the front-right. Weird, I thought. About a week later the Tire Pressure System Inop light came on. So anyway, I got rid of the rubbish Michelins two days ago and bought four Hankook Ventus Evo2 K120s and had the senders replaced. Took a 75 mile excursion and while driving the Left Not Monitored light came on, went off, then the RIGHT Not Monitored came on along with the System Inop light. GRRR!!!!
I had bought three used Land Rover antennas off eBay for $10 Just In Case, so I changed the Right Front Antenna and drove about 12 miles..... and...... all the lights went off. Turned off the Jag and let it sit for awhile before trying again. No Lights! Drove for another 10 or so miles with nothing bad and parked in the garage. Went back out a couple hours later and fired 'er up and STILL no lights.
HOPEFULLY this will have worked. A bit of work, but only $3.33 with free shipping. Two spare antennas.
Crossing my fingers................
Okay, so it's now been 4 full days since I've had any tire pressure warnings. I've done nothing to the tires since this all started. But whatever it was has seemed to work itself out. Having said that, other odd things have happened over the last couple of days. On several occasions, I have had the "key fob not recognized" warning with instructions to insert into the holder in the arm rest. My car would not start one morning, and I had to use my portable battery charger to get it to turn over. The battery is less than 6 months old, and it hasn't happened again. And by the way, each time I attempted to start the car when the battery was dead, the windshield wipers went on and stayed on until the next time I tried starting it. I'm not quite sure what's going on.
