Tire pressure system fault .
Give the owners manual a read Mar-Vel (nice vert btw). If you don't have the manual, check this out
https://www.jaguarforums.com/forum/s...rchid=14030202
Your Public Profile shows that you have a 2007 XKR. One or more of the batteries in your TPMS sensors may be dead. If so, you should replace all 4 sensors. A tire shop can scan your sensors and determine if they're still OK or need to be replaced.
TPMS batteries are molded in the sensor and are not replaceable. Sensors usually last around 7 years, but have been known to last much longer. Replacement sensors need no programming.
There are many TPMS threads on this Forum.
tommytess (01-23-2021)
That may be an option in the USA. Here in the UK and the rest of Europe disabling mandated safety systems is a no-go as several Bentley Continental GT owners (I was one of them) have discovered.
The Jaguar TPMS consists of 4 elements:
1. tyre pressure Sensor (on in each wheel as part of the valve assembly
2. tyre pressure Initiator (one in each wheel well)
3. Tyre pressure Receiver (one per vehicle. 315 mhz for US market and 433 for European market)
4. TPMS Module (two revisions of this component)
The Initiators are in a vulnerable location behind the wheelarch liners. This is my RH rear:
A fault on an individual wheel can easily be the Initiator (failed / broken wire / bad connector) rather than the pressure Sensor.
Once replaced, a 15 minute drive above 20 mph will register the sensors to the car. There is no need to program them to the car. Once registered, the warning light will go away.
As GGG mentioned, replacements are the 315 Mhz variety.
AS A SIDE NOTE: Also as GGG mentions, TPMS is required in multiple countries and is required by Federal Law in the US as well. Those who live in States that don't require inspections, can disable it using SDD but I'm not advising anyone to do that.
GGG (01-23-2021)
Graham.
You can download the XK Owners Handbook 2007 - JJM 10 02 30 801 (free) from my MediaFire online storage:
https://www.mediafire.com/file/e3cii...0_801.pdf/file
GGG (01-24-2021)
From the Googs...............
"Phase-in started in October 2005 at 20%, and reached 100% for models produced after September 2007. In the United States, as of 2008 and the European Union, as of November 1, 2012, all new passenger car models (M1) released must be equipped with a TPMS."
Besides, in a few minutes, my 2010 "Doesn't have TPMS" either.
In the EU TPMS became mandatory for all class M1 vehicles (passenger vehicles with no more than eight seats in addition to the driver's seat) registered after November 1st, 2014. The initial legislation (UN ECE R64) was approved in 2009 with a two-year phase-in schedule starting from November 1st, 2012.
Now let's get back to the topic of Jaguar TPMS faults.
OK Graham. I think the OP will best be served having a tire shop check the batteries. It's the most likely cause.
My TPMS adventure:
The warning came.
I had the tries shop confirm all sending units in the tires were sending strong signals and they chowed me.
Was driving me nuts and I didn't want to disable the TPMS in SDD
Swapped out the receivers - all of them. Nope.
Replaced the module - Nope
Then once while driving - my media box connection (on screen gauge display) failed to recognize the OBD II dongle
I unplugged it but was driving so wasn't about to trying plugging it back in until I stopped.
The warning light went out
Plugged it back in sometime late and it reappeared.
Eventually went to a wifi dongle and the light didn't return but I didn't much care for the wifi setup as my media box kept defaulting to my home wifi and it took too much time to swap it
Solution - disabled the TPMS
I know CeeJay has done all of the same but even when switched to the wifi dongle, he still had problems.
Again, I'm confident this is not the OP's problem with the original sending units still in place.
My TPMS adventure:
The warning came.
Received 2,048 Likes
That's not correct. I have the vgate iCar Pro OBD scanner (recommended by CabrioBob for use with his Ashtray Display Unit) and it works over Bluetooth with my iPhone (loaded with the OBDFusion app).
