Tire pressure system fault warning
I had bad results with “universal”, non OEM guaranteed to work on my car sensors. I ended up buying OEM ones from LA Jag online. Better price than any other OEM source and they worked.
my dissapounment with the TPMS system though:
- it only shows low pressure. You can’t simply check pressure, like most all other cars for the past 25 years.
- you can’t use a scan tool tool to check the pressure after the car has been sitting. It seems they need to rotate to turn on.
Part of my list of quirks..that are sort of endearing.
StellaLunaGardens
07-07-2020 04:14 AM
