Tire pressure warning jumping tire to tire
This past week, on my 07 XK coupe, the low tire pressure warning has come on and intermittently will jump around to all 4 tires randomly, then go off. I checked and double checked the pressures today, all are where they should be. Any ideas? Thanks!
tmich (03-16-2023)
That did solve my little light show.
WJ
Cee Jay (03-16-2023)
I have the same thing. Went to Discount tire and confirmed all the in-tire sensors were working and they "reset" them. I drove 30+ miles with it still happening pretty much the whole time, then shut the car off and when I restarted, it appeared to clear the issue. It happens much less now, but still intermittently. I do need to get the battery checked, as I have no idea how old it is, before looking into buying any Module or receiver parts. I haven't noticed any other "low battery symptoms", but it's relatively easy to have it checked.
Good luck and keep us posted.
My first thought was battery too... I keep it on a trickle charger and don't remember if I replaced the battery when I purchased the car a couple summers ago... ugh. I keep records, I need to check on it.
Where is the TPMS module located? We're not talking about the wheel sensors rights? I goo'd up one of those a few months ago lubricating bushings to get rid of an annoying squeak, that set off the ABS failure light until I cleaned the sensors off. 🙄
I've fought this issue for two years, two new sets of TMP, new Ctek, only thing that worked was to overinflate tires by 5 lb's.
This spring when I bring it out of storage I've found a local garage the specializes in Foreign Cars and they will turn the system off.
Drove the first 55 years without the damn warning, guess I can do it today.
My X150 has done the same for about a year. Never had any fault codes for TPMS but intermittent "check tire pressure" messages and the TPMS warning lamp would come on steady but not flashing (the amber exclamation point inside tire). The false low tire pressure messages would randomly rotate around all four tires for approximately one minute then disappear.
Troubleshooting included over inflating, deflating to test appropriate indication, had tire shop scan all four sensors in wheels to confirm sensor battery levels, charged battery, and even replaced battery. Yesterday I took it to the JLR dealer for diagnostic. Technician verified correct tire pressures and sensors broadcasting with warning lamp and tire pressure messages. Initially he recommended replacing all four TPMS sensors with "factory" sensors. Service representative asked me if they were OEM sensors?
Thankfully a "team leader" suspected the TPMS module may be jammed or confused so they performed a hard reset and an UPDATE to module. Amazingly they realized it was communicating correctly before replacing any wheel sensors!! Charged me for diagnostic service only. So far so good. Drove it for two hours yesterday without any tire pressure warnings.
Update - Last week I replaced the TPMS sensors since the cost wasn't prohibitive. Scan tool indicates they're active and recognized. Unfortunately the problem was not solved. I purchased a new module from an Jaguar Dealership online, the price was $186 I believe. I removed the rear seats and installed the new module, but the TPMS fault light came on. Phoned my local Jag dealership, service manager states that the module needs to be programed and they have the software. That will be my next step.
McJag222 (07-08-2023)
Update - Last week I replaced the TPMS sensors since the cost wasn't prohibitive. Scan tool indicates they're active and recognized. Unfortunately the problem was not solved. I purchased a new module from a Jaguar Dealership online, the price was $186 I believe. I removed the rear seats and installed the new module, but the TPMS fault light came on. Phoned my local Jag dealership, service manager states that the module needs to be programed and they have the software. That will be my next step.
I pulled the fuse F2 5A tan and turned car on. (Rear seat compartment fuse box). Then turned car off and replaced the fuse to reset the TPMS module. Still had tire pressure warnings.
I've ordered and received a TPMS control module but haven't replaced it yet.
The technical bulletin for TPMS control module reset issue (JTB00317NAS2) says to program module with SDD v.138 or later. My Mongoose Pro cable came with software version 138 so I intend to use it to program the replacement module.
Interesting. I did swap the modules, but no recognition. I noted that the new module has a new updated part number and is made by a different manufacturer than the original, but per the Jaguar part numbering system, the new module is intended as a direct replacement. I was a tad taken aback when my local service manager had to check and see if the dept still had the programming software for an 07. 😳
So, after 4 months I believe my issue has been resolved (fingers crossed). I went on e-bay and for $55.00, purchased a used TPMS module (from a car with 30k miles). I specifically chose a module from the original manufacturer with matching serial numbers to my faulty module. I received and installed the module today. Upon starting the car, the 'TPMS fault' triangle came up on the dash, but within 10 minutes of driving, the fault cleared and the intermittent "rotating under-inflated tire warning" has not returned.
I believe that the new module I purchased from Jaguar simply wasn't compatible without programming from Jaguar. The price I was quoted from my local dealership was $325.00 with the proviso that there was no guarantee the programming would be successful.
Panelhead
06-18-2021 07:37 AM
Ntimd8
08-12-2019 05:32 AM
