tire propellant?
Hey Guys,
As an owner of a Jag that only has the emergency inflator pack, what's a body to do? The propellant expired a couple years ago and I'm starting to feel mortal. LOL!
I know I can search for the XJ Supersport spare tire kit etc, but, I really like the extra room that vacant hole offers. Have also learned, once the propellant is used, the tire may be permanently damaged, as well.
So, what are the rest of yous guys doing?
A followup question.... Can the Jag inflator be used without's it's propellant pack?
Received 2,670 Likes
You can use the inflator without the gunk - I did it a while back when I discovered a flat. I'd always try to reinflate the tyre before filling it with crap, because there's always the possibility that it's a slow leak (which turned out to be the case).
There are other sealer products, including some that are water-based and don't cause any issues if they are left in the tyre and can be washed out if the tyre is deemed repairable. But I'm not sure if they can be plugged into the Jag inflator. It's possible you'd have to squirt the gunk in separately, and then use the inflator.
GGG (07-10-2015)
So, is it possible to use the Jag inflator without the gunk that comes with it?
Now that I've re-visited this, I'm thinking along the lines of what White XKR mentioned...., obtain an inflator and a DIY tire repair kit. But then, you have to plan on the puncture to be visible, else, the tire needs to be rotated in some way to expose the offending nail, screw etc.
I like there is a more friendly sealant that won't render the tire useless. I'd hate to replace a $300 new tire due to a simple nail.
RedRider48 (07-10-2015)
jagtoes (07-10-2015)
I always carry a can of 'fix a flat' it works great, yes tire places don't like it since they have to clean up the mess. I started carrying it in my old Carrera 4 as there wasn't much trunk space with the space save and the rear wheels would only fit in the passenger seat so if I had company something was being left on the side of the road!
I was thinking earlier today of removing the space saver for the extra space, so my vote is ditch the donut.
Andy,
Don't simply ditch the donut; replace it with a Bible so you can pray that you never get a non-repairable flat! Why Jaguar didn't fit runflats to models without a spare is beyond me.
Stuart
Stuart
Last edited by Stuart S; 07-10-2015 at 11:16 PM. Reason: Deleted unwanted link to a tire website. No idea how it got in here.
andys-GR (07-11-2015)
My 2009 XKR Portfolio came with the same kit as your 2008 XKR Portfolio since both our cars have Alcon brakes. I was concerned about getting stranded with a non-repairable flat, so I added a compact spare. For details, see: https://www.jaguarforums.com/forum/x...-brakes-67260/
Stuart
I bought the spare donut tire for my 2009 XKR portfolio edition. I also carry a DynaPlug Tire repair kit as a backup if needed. Easy to use.
In fact none of my premium sports cars have a spare tire except the XKR now. I bought a small 12v air compressor to carry along with the tire plugger. I never have any worries.
Amazon.com: NEW Portable Mini Air Compressor Electric Tire Infaltor Pump 12 Volt Car 12V PSI: Home Improvement
With these accessories, I should be able to make it home or to a tire repair sho[p.
![Amazon.com: NEW Portable Mini Air Compressor Electric Tire Infaltor Pump 12 Volt Car 12V PSI: Home Improvement](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
You can probably find a used Jaguar jacking kit on eBay. That is what I did and paid about $40.00.
What years will the jacks cover?
