Top Stuck
Top Stuck
Hi All just reading his post, I have the same kind of problem, it has started since I took the battery off, just bought the car its not been loved and is filthy I removed the battery as it had a new one fitted before I got the car, the old one had leaked for some reason, probably the vent pipe was pulled off, anyway there where signs of acid spill around the battery and dribble into the spare wheel well. I opened the hood half way propped it open so I could get a better access cleaned everything up put the battery back on and now I have a non functioning hood?
To begin with it wouldn't operate at all it was stuck in the half way position.
Then it seemed to lose pressure and sag, I had to lift the bow then lift the tonneau cover above it.
After a few attempts the hood opened fully and then closed OK but now wont open or close?
tried releasing manually but it sticks just a few centimetres up from the widescreen.
It seems the bow is not lifting at the back
Rear windows are now stuck down
Is this a jammed ram or has the system got out of sequence
If out of sequence can it be re set by me or is this a dealer fix?
thanks in advance
RDS
thanks in advance
RDS
Received 6,339 Likes
This is an X100 car?
Try putting the top down manually following the instructions from Gus's site JagRepair.com - Jaguar Repair Information Resource
robtroxel (08-06-2017)
Hi, no its a X150
I left it for a couple of hours then tried a manual open, it went quite easy, on the 150's you can see the rams when the top is open by pushing the closer back on either side, the activation cord un-clips. I made sure both rams where full back then by mistake tried to close it with the valve still open !!! I let the pump run for a few seconds wondering if it might help purge air out of the system.
Clsed the manual valve and tried it, all seems to be OK, it was a bit sluggish the first time I closed it but back to its normal speed now.
Fingers crossed that was an hour ago I'm about to try it again now
Thanks for your reply
Now to sort out the wiring harness under the seats (air bag light coming on) and try and find why it intermittently shows a gearbox fault must be a bad connection somewhere
Hi, no its a X150
Stu 1986
09-11-2024 01:22 PM
davidladewig
33
05-25-2017 08:46 PM
androulakis
01-10-2007 10:37 PM
