Touch screen not very bright
The touch screen on my new to me 08 xkr vert is not very bright ,I can not see it at all when the top is down and the sun is out and Im driving,I have to ask my wife to operate it, no,I have good eyesite, I have ajusted the brightness and dimmer up but no better,Is this a problem or is this the way they they are. BL
![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
You will probably get a better response by posting your question in this section. We only know about the first generation XKR here. Touch screens are way too modern for us
sherbercars (07-21-2011)
The touch screen on my new to me 08 xkr vert is not very bright ,I can not see it at all when the top is down and the sun is out and Im driving,I have to ask my wife to operate it, no,I have good eyesite, I have ajusted the brightness and dimmer up but no better,Is this a problem or is this the way they they are. BL ![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
I have the 08 XK Convertible and have the same problem. No amount of adjustment makes the screen any easier to see with the top down and under bright sun. The screen is fine under any other condition and to be really fair, this problem is not unique to Jaguar. I used to use a Garmin GPS in my old Pontiac convertible and had the same problem. I just do not believe the current active matrix technology in LCD panels is quite up to taking on blazing sun shining right on it...![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Tom
sherbercars (07-23-2011)
On the display, select Vehicle and on next screen select System Settings. Press the down arrow that appears at the bottom center left of the next screen. You should see two choices - a green-based and a blue-based display.
Hope this helps!
Hope this helps!
The following 3 users liked this post by jimatvs:
Only the touch screen display color changes.
Finbarr1975
09-16-2023 02:52 PM
jimforrest (uk)
02-28-2019 06:42 PM
