Touch screen pre-set question
Okay, finally got my gently used '07 XK delivered to Dallas from Ohio and I've been setting up all my preferences. There are two items that are not explained at all in the Handbook. (Yes, I have actually been reading it!!)
1. Under the Security folder there is a setting labeled "Intrusion/Tilt". It gives options as either On or Off. What is this for?
2. Under Systems Settings there is a Volume Presets folder. Among other things it lists "TA". The volume can be increased or decreased for this. What is TA?
Help would be appreciated. Thanks
Intrusion/tilt is to detect if the vehicle is loaded onto a trailer or moved while the engine is off or if one corner is jacked up to remove a wheel.
TA is Traffic Announcements
XJJags (07-21-2012)
trosty
26
12-18-2022 06:40 PM
