Touch screen, radio, and ac inop
Old 03-31-2023, 09:58 AM
Sean W's Avatar
Received 4,219 Likes on 2,367 Posts
Also, during any previous work, you didn't by chance or accident, pull the FO lines from any connector? The feed is directional and there are in/out arrows on each connector. Essentially if you swapped them and are sending a final in the out port.... It doesn't appear to be your problem but worth asking.
FWIW, it's very unlikely the FO broke on their own (unless mice?). It's more likely if they're broken at all it would be human error. You did work in the center stack You have 3 things to check right there. Also, the FO line going back to the trunk stack - Pull the hump between the seats and you should see it and trace it backward. I can't recall exactly where but there is a connector that links the center stack to the trunk stack and if you put your loop there, you'll eliminate anything in the trunk from being the problem.
guy (04-01-2023)
Old 04-01-2023, 05:54 PM
Byrdro's Avatar
Sorry, so just because i dont know exactly how the jump is working i plug both bypass pieces in, outside this module and another due to the different hookups. I get light here that flashes at a steady slow pace. But when i hook up and go to the next device in the back stack i do not get a light from the cable when i hook it. So tells me that this module is a problem or FO cable is the problem. And i did go through and double check to make sure the cables were seated properly in their connectors. That's why I was wondering if I can just get a cheap laser pointer and shoot it through to make sure the cable is good.
Old 04-01-2023, 05:56 PM
Byrdro's Avatar
or is this the culprit and my dumbest forgot to plug it in somewhere and dont know where is goes 😅😅
Old 04-01-2023, 06:54 PM
Sean W's Avatar
No that's just a connector used by Jaguar for transport. It's ok to ignore and serves no purpose.
Old 04-01-2023, 07:02 PM
Sean W's Avatar
OK just to make sure we're saying the same thing as I'm confused by your writing, when you pull the FO cable from the Harmon Becker device, you should connect to loop to the FO cable. The module is left alone at this point. Then test your touchscreen. Essentially you just took the HB module out of the loop, so the beam of light is now looped back and returning to the previous module(s). If your screen is now working, you may have found the module. If not, reconnect and see if you have light at the next module, repeat.
Byrdro's Avatar
OK, thank you. So it is the module. Buying replacing and seeing if it fixes the issue.
Old 04-01-2023, 07:04 PM
Sean W's Avatar
It's just so very rare for a FO line to break unmolested. Unless you have mice...
  #28
Old 04-01-2023, 08:07 PM
Cee Jay's Avatar
Received 5,360 Likes on 3,174 Posts
....................................... That's why I was wondering if I can just get a cheap laser pointer and shoot it through to make sure the cable is good.
Don't use a laser pointer, a regular ole flashlight will work fine.
V7Sport (04-02-2023)
Old 04-01-2023, 08:48 PM
Byrdro's Avatar
I understand, I work on tanks and they say the same thing in the senior school house. It's always a mix, I just wanted to verify to make sure I only spend the money I need too
Thank you all for your help. Once I replace that module I will give an update
Sean W (04-01-2023)
  #30
Old 04-01-2023, 09:06 PM
Sean W's Avatar
so now once the loop is in and you bypassed the Harmon Becker module, the touchscreen was fully operational again?
  #31
Old 04-01-2023, 09:26 PM
Byrdro's Avatar
The issue is the connector body for that module is different than the rest, I do not have a test for that connection.
So I had to test via flashlight. I tested from that point and connected and disconnected every module to make sure light was traveling through, it did at all points.
So right now i can only assume that module is the one that has failed.
And to be clear the module on the right side of the trunk is the audio amplifier?
  #32
Old 04-01-2023, 09:46 PM
Sean W's Avatar
No I it's the iPod module aka Portable audio interface module, The Amp is located in a false bottom under the passenger footwell. Page 2 of the PDF Bill400 posted is your friend here. It gives you the order and location of each module.
Also - Do not use laser pens to test the fibre optic cable's ability to pass light
  #33
Old 04-02-2023, 07:31 PM
Bill400's Avatar
Using a dependable voltmeter, check the 12V power to the suspected "defective" module.
You likely will be checking B+ on the connector to ground.
Verify your test aparatus and ground point using a known good B+.
Then confirm the module connector B+ using the same ground point.
The optical transceiver will not pass the optical signal if there is no power to the module!
Make sure that the pin is properly seated in the connector and the connector is properly seated in the module.
Sean W (04-02-2023)
  #34
Old 04-06-2023, 05:50 PM
Byrdro's Avatar
So to reply back to Sean and Bill, yes so after testing and fiddling with things today. Two things I found, fuse 31 in the back passenger was popped for the power Amp. And I am not receiving power at the harmon beck. My question now is where do I look for that power. I'll take a dive in the schematics in a minute, but I only have 1 day left with the family then I have to go somewhere for 2 months. Trying to fix this by wnd of day tomorrow if possible. All other modules have power, the only one I did not check is the one under the seat. Which I assume is under the driver's seat for an American version. Again thanks for the mentorship sorry if I am slow at getting it
Edit: so I ended up finding the problem, it was a blown fuse on 24 in the back passenger fuse box. The only issue was that in the manual its a fuse not used. When i initially seen it i thought it was a fuse i replaced but was in a hurry and stuck the blown fuse there. So for my car i assume the power runs through there and goes to my back left module.
Now my issue is I'm not getting the blower motor to run
The following 2 users liked this post by Byrdro:
McJag222 (04-06-2023), Sean W (04-06-2023)
  #35
Old 04-06-2023, 07:02 PM
Sean W's Avatar
The Harmon Becker module is referred to as the AUU and it's fuse 24 in the Aux fuse box. You can check F21 for grins too and you have the Amp covered.
Byrdro (04-06-2023)
  #36
Old 04-06-2023, 07:05 PM
Byrdro's Avatar
At the same time. Do you know why my blower isn't running. I replaced it and it worked fine before the screen went out
  #37
Old 04-06-2023, 08:47 PM
Bill400's Avatar
Hooray!!! Good work!
You are now a little more familiar with your Jaguar, reading the wiring diagrams and location of components.
It gets easier as you gain experience.
Good luck, keep us posted.
  #38
Old 04-06-2023, 08:50 PM
Sean W's Avatar
good news. advise you start another thread on the blower motor.
KILOCHARLIE
05-23-2022 11:21 AM
DannyA
XE ( X760 )
06-12-2021 07:53 AM
Wade Brooks
08-02-2020 06:47 PM
Mohab
08-16-2019 07:28 PM
ODIN
07-15-2008 10:37 PM
Quick Reply: Touch screen, radio, and ac inop
