Touchscreen does not activate
After I didn't drive my car for a week about 2 weeks ago, when I went out to start it, it started right up but no screen, just black. Restarted the car several times with same results. Not only did the touchscreen not work but none of the controls below it on the vertical console. So, I couldn't turn off the A/C, or change temperature, or turn off the radio or change the volume. Drove the car home for about an hour and still no change. Restarted the car and screen was still black. Then I decided to lock the car and then reopen and then restart the car, and everything has been back to normal ever since. It was definitely a battery issue, but it also needed the "reset" instigated by locking the door. Try it.
75% of the electrical gremlins with these cars is because of Low Battery.
ALSO, sometimes a Hard Reset fixes the weirdest things;
Hard Reset = remove the positive battery from the battery and touch the clamp to the negative cable. This discharges all the volatile memory in most of the modules. DO NOT touch anything to both battery posts, or battery cables while still connected to the battery!
Out of interest how long after locking it did you reopen it? I haven't had any battery problems on my '10 XKR but in the early days on my '07 XKR I had to wait for it to drop out of convenience mode before the screen would come back to normal.
u102768 (10-03-2019)
Yes, indeed it does, or rather, can. Low battery voltage can and does give any number of random symptoms including the two you have mentioned. You may be due for a new battery - if so, please note that new batteries are almost never fully charged and often never get fully charged! Make sure it is brought to full charge before installation.
