TPMS/OEM Parts Online?
Is there any website that sells Jaguar OEM parts for less than the dealer? I need to buy 4 TPMS sensors plus the tool to put it on (according to the dealer).
Also,I was told the TPMS runs either 315 MHZ or 433 MHZ. Just want to confirm U.S. model XKRs run 315 MHZ?Thanks.
RE: TPMS/OEM Parts Online?
i can probably get them for you cheaper then the dealer.. and there is no special tool.. the tires do have to be broken down to get the valve sensors in.. just need socket and rachet to install but that hold the sensor in.. i think the frequency is 315 mhz i check tomorrow
ORIGINAL: jag_genius
ORIGINAL: FactoryJaguarTech
Definitly 315Mhz. You should be able to transfer the sensors from your wheels to the aftermarket ones. At least that is what we do. Only had one set of wheels that we couldnt fit into.
Scott B
10-24-2015 01:29 PM
Wes Steenrod
09-06-2015 06:52 PM
