TPMS-Tire Pressure Monitoring Sensors
#81
#82
Why pay an hour's labor cost of $125 or more when there isn't any need whatsoever?
#83
![Icon That](https://www.jaguarforums.com/forum/images/smilies/icon_that.gif)
I've been on this Forum for almost 10 years and have never seen a thread about needing to have TPMS sensors programmed to the proper frequency before being installed. That simply doesn't happen because they're sold already set to the proper frequency, either 315 MHZ or 433 MHZ, depending on your location. Any installer who tells you otherwise is either ignorant or trying to rip you off.
pwpacp (06-03-2020)
#84
Your car will relearn new sensors. If you rebuild the HEX code should remain the same. If they are put on at different locations than they came off, your car will relearn there new location. It will relearn a new HEX as well. If system fault comes up, drive the car for 10 miles or so between 18 and 60 mph and everything should return to normal.
#85
#86
Yep. Using SDD to do the sensors, SDD dictates that the spare be installed and driven, then the regular wheel/tire be put back on and run again. I tried this to fix all my TPMS problems but it didn't help anything.
#87
#88
#91
Cee Jay (06-14-2020)
#92
#93
Autel MaxiTPMS using autel sensors....zip, zero, nada problems. Install them, start the car drive 8 or 10 minutes at over 20mph....done, or, just program the ECU with the Autel unit, clear any DTC's, start your car and go, no "learning" required. Autel MaxiTPMS has Jaguar software pre-installed, you just pick the model.
#94
Talking about Autel sensors programmed with an Autel MaxiTPMS. Works beautifully. If you program the sensors, then plug up to OBDII you can transfer the info from the programmer directly to your ECU, clear any DTC's and then no "training" is required, start the car and it doesn't have to learn at all because you programmed your ECU prior to driving. Piece of cake.
#95
#96
Received 2,012 Likes
#97
#98
A couple of ways to look at it Bocatrip. Average life expectancy of a TPMS sensor is 7 years so 10 year old sensors are on borrowed time. That said, I replaced my TMPS sensors separate from a tire change and the labor cost was $10 per tire. $40 more doing it as a one off and that assumes they would add the full $40 during a tire change which I doubt.
#99
Buyer Beware! The price of TPMS sensors with the identical part number can vary widely. Why? TPMS batteries are molded in and are not replaceable. Be sure to check the date on the sensor. The older the sensor the cheaper the price, since the battery life grows shorter as the sensor gets older.
A cheap sensor is no bargain if its battery dies shortly after you bought it.
murphman
12-05-2014 11:06 AM
