Transmission a bit snatchy
I’ve noticed recently when I put the my 07 xkr in D and try to pull away gently it won’t and seems to pull away like I’ve pressed the accelerator harder than I have. Don’t get me wrong it’s not a big change but I can tell. I’m going to have the gearbox serviced as there’s no mention of it in the service history but I was just wondering if anyone else has come across this.
I bought the car a few months ago from very rural west Wales and I’ve been using it to commute from the midlands to Cornwall, im wondering if a gearbox reset might help too?
A couple things are at play here...
The car learns how you drive and wants to continue in that manner. If you usually pull away hard it will always WANT to pull away hard. To undo this, you must do a hard reset using the battery cables. It will relearn your driving style again, but it takes awhile.
ALSO, how many miles since you changed the transmission fluid? Every 60,000 miles is pretty much required, and ten years regardless of mileage. In THAT case, EVERY fluid on the entire vehicle should be changed. All seven of them.
jahummer (07-17-2023)
I also find 1st gear a little snatchy it just feels like it's geared way too low. I had the transmission serviced which helped a little but it's still difficult to get a really smooth pullaway especially with the engine cold. I find myself selecting 2nd once stopped which gives a lovely take off and the car jumps back into auto after a few seconds, not ideal but much smoother.
Here
https://www.jaguarforums.com/forum/x...useless-84675/
as well as in the F-Type forum a discussion can be found, which seems a bit confusing…
(So I feel relieved that my question maybe wasn’t as silly as I thought.)
My new to me XK, does start off quickly from the stops. I can stop that by one click on the +paddle, and it will depart in 2nd gear, and reset to D shortly afterwards. Also I am thinking "to clean the throttle body" before resetting the ECU, to fix the problem. My new Mongoose is in the mail.
