Transmission in quicker in 2012-2014 XKR?
OK, Tried it today on way home.
Buy One! It does exactly what you are looking for.
First of all, both downshifts and upshifts are faster than the display can change, and there is no silly speed limit to when you can go into 1st (within reason I presume)
Its lighting quick! And yes you can jump from 1st to 3rd as fast as you pull the lever.
You must know some good roads where you will put all this to use. One note, while there is no lag whatsoever, the throttle is cut ever so slightly so as to remain civil to your clutches and self- but you wont notice it other than the lack of the thump.
![Icon Bricks](https://www.jaguarforums.com/forum/images/smilies/icon_bricks.gif)
I did three rapid clicks, it went from 6th to 3rd quite rapidly at 50MPH, about as fast as the engine could rev up the difference.
My impression with the XK's gearbox, is that it is quite acceptable for an automatic. It surprised me on the test drive. I'd been only owning manuals from my first car onward.
Queen and Country (06-29-2017)
