Trap door - convertible top
I’m not sure what to call this part, but it’s a sliding trap door on the upper surface right behind the drivers door. There is one on both sides. This slide out of the way when the top is up and slides in place to cover the hole up when the top is down. I can add pics later if I need to. But, the issue is that this part appears to have jumped out of track and it popped the cord that pulls it into place when the top goes down. So right now it’s just stuck out of the way and my car has a 3” x 6” rectangular hole that is left uncover s when the top is down. I called jag dealership and was told u have to buy the entire interior panel at about $1000 to get this part. Anyone else had issues with this ?
Jaguar has a useful TSB on repairing the sliders, with part numbers. I have attached it. If only the string is broken some people have done DIY repairs documented here. Search for 'slide' or 'slider' in this group.
LoudHogRider (08-26-2020)
With mine not only is the string broke(I’m sure I can fix this) but it seems to no longer slide smoothly in the tracks. Looks like it has red grease all over the tracks like maybe the previous owner had issues and greased this area. I probably need to pull this apart to look at it closer.
SNG Barrets T: +44 (0)1746 765 432
sales.uk@sngbarratt.comat 913-677-7653 One of these companies should be able to help you.
