Trickle charge for 2013 Jag XKR coupe
With the 2010-2015 MY cars you can either use the positive post behind the left plastic grill in the boot and the ground stud in the spare tire area or you can attach the positive lead directly to the battery but you must NOT attach the negative terminal . It should go to a chassis ground near the battery. The 2010-2015 cars have a battery monitoring module attached to the negative battery terminal. You should only hook up down stream from this module. Happy motoring
JonWat (09-06-2018)
I have owned my car for 18 months and it has never been on any kind of charger, ever. If the battery is in good shape and the alternator works then there is no need. Using a battery charger on a weak and failing battery is like putting lipstick on a pig. Just about everyone on this site says to use a C-Tek ? charger, it cures all kinds of aliments apparently and that the electronics on Jaguars are somehow different to all other cars ever made and need constant charging, when really all they need is a decent battery. If you are storing your car over winter and live up North then maybe one is required but I have left my car for more than three months and it starts right up with no issues. Just crank the thing up every month or two months and let the fluids (oil) get up to temperature and all will be well. My 10 cents.
Use of the CTEK (or similar) maintainer eliminates any and all of these problems. It takes no more than a few seconds to connect and disconnect the maintainer but the result of using it is zero electronic issues caused by low voltage, and a greatly increased length of battery life. If you do not believe this, stop by a dealership, any dealership, of a luxury make. Chances are that you will find the showroom cars plugged in to battery maintainers discretely placed under the cars. Modern cars are voracious consumers of electricity.
It seems that you live a blessed life. Here are some facts: many of these cars are not used on a daily basis and/or are used for short runs. The result of this use/lack of use is inevitably over time a drop in the voltage that the battery (yes, even a new battery) can supply, despite the car having a perfectly functioning alternator - and when the battery voltage drops below a certain threshold there WILL be issues. The car will always start (unless the battery is near death) - that is not in question. But what WILL happen is that certain modules will not operate properly and random symptoms will appear, ranging from odd warning lights, to the convertible top not functioning properly, the touch screen misbehaving, the windows not dropping to allow opening the door, exterior lights flashing...the list is long and varied. This is not a "Jaguar issue" . Every luxury manufacturer (Bentley, Maserati, Jaguar, BMW, Mercedes, Range Rover, Aston Martin...) has marketed through their dealers the CTEK battery maintainer (not charger) with their own name on the unit. They all do this for the same reason -the reason I have just stated above.
When I first got the XK, I was resistant to the maintainer "hype" because logically thinking, a car driven every day or so doesn't need one. Why do I need it? Well, the first time it sat for a week with the doors unlocked, I started seeing the oddities related to a low battery. Ordered the C-Tek and put it on if the car is going to sit for a few days or more, or when I'm cleaning or doing something where the doors or boot are open for a while. No problems since.
Hey if it ain't broke, don't fix it but I think we all agree Mufc's situation is rare.![](https://www.jaguarforums.com/forum/images/icons/icon10.gif)
I've had my 2010 hooked up to a generic NAPA
*Thanks, Stuart S
For those not familiar with the BMS here is a brief description how it works. FYI http://www.londonroadgarage.com/imag...monitoring.pdf
MarkyUK (09-06-2018)
Many people use the words "trickle charger", "battery maintainer", and "battery tender" synonymously, but they're not identical.
A trickle charger is not the same as a battery maintainer. The former is dumb and the latter is smart. Dumb means that it charges slowly at a constant rate and doesn't shut itself off, so it can boil out the electrolyte and destroy the battery. Smart means that it is controlled by computerized circuitry that varies the rate of charge depending on the type and condition of the battery and can shut itself off when fully charged and turn itself back on when needed, so it can't boil out the electrolyte.
"Battery Tender" is the brand name of a line of products that are marketed by Deltran Corporation. I do not recommend them, as my Battery Tender, Jr. (made in China) overheated and melted the plastic case. It was less than 6 months old. Fortunately, it didn't burn down my home. You're playing with fire if you buy a Deltran Battery Tender.
I highly recommend the CTEK brand of battery maintainers, particularly the MUS4.3. It works.
... Every luxury manufacturer (Bentley, Maserati, Jaguar, BMW, Mercedes, Range Rover, Aston Martin...) has marketed through their dealers the CTEK battery maintainer (not charger) with their own name on the unit. ... If you do not believe this, stop by a dealership, any dealership, of a luxury make. Chances are that you will find the showroom cars plugged in to battery maintainers discretely placed under the cars. Modern cars are voracious consumers of electricity.
The newest, latest and greatest CTEK battery charger costs only $1,890,000!
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/20151027_095119_45fe2bf44cd37ee4fec6699a981270764c4d5242.jpg)
But you also get the Koenigsegg Regera free! What a deal!
MarkyUK (10-06-2018)
TreVoRTasmin
08-18-2020 09:21 PM
FLYINGFOX4475
05-11-2017 11:56 AM
Pookster208
02-13-2008 03:14 PM
