Trickle Charger...
Greetings, my XKR 2009 will not be used for three months and it was suggested to me that I buy and install a "Trickle Charger" that will ensure that the battery remains charged while the car is not in use. My Jaguar Service Center told me that I could buy these in many stores and all I had to do was attach it to the + and - of the battery in the trunk and plug the device into a 110 outlet (Canada) Has anyone ever done this ?
Upon receiving the above devices I tested each one for current output and they all put out the advertised 0.5 - 0.6 Amp. That is a very safe amount for float charging. However, one claim it make is not there; it does NOT show when the battery is charging and when it is not. The picture shows it to have a read and a green light but, the ones I received have only the red lights that light up as soon as you attach the Pos and Neg leads to the battery. You can not tell when it automatically shuts off. There are many similar automatic devices on the market, so take some time and find the one you like.
Albert
abela (05-13-2013)
Received 2,263 Likes
You want a float charger or a battery tender, not a trickle charger. There is an important difference. Here's what I use on all the toys over the winter:
Battery Tender Plus, 1.25A Charger/Maintainer | Canadian Tire
BTW- Canada, including Quebec has 120 volt AC not 110. Even Mme. Marois has no 'power' over that.
![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
Muddydog (05-13-2013)
Mikey... Thanks for the info. Yes 120 V oooops. Will that battery tender shut off automatically once the battery is fully charged ? And another question... the battery is in the trunk, will I be able to close the trunk with the wire hanging out ? Otherwise the trunk light stays on, running the battery down... granted I probably could unscrew it...
Albert
abela (05-13-2013)
abela (05-14-2013)
So much has been previously written on this subject that I feel like I'm
(I've always wanted to use this and finally got the chance to do so!)
Battery chargers have been extensively discussed in the following thread: https://www.jaguarforums.com/forum/x...lay-ups-73471/ See my posts ##17, 19, and 21, which has detailed photos.
Before you buy a Battery Tender brand, be sure to read the user reviews on Amazon.com, including mine. Since I was not a satisfied customer, I will never buy anything from them again. I am pleased with the BatteryMinder Plus brand charger that I use daily on my XKR and bought on Amazon.com. There are other equally good brands, so do your research and buy the one that best suits your needs.
Hope this helps,
Stuart
![Icon Deadhorse](https://www.jaguarforums.com/forum/images/smilies/icon_deadhorse.gif)
Hope this helps,
Stuart
abela (05-14-2013)
If you want to verify this, leave the trunk open and check on it in a half hour, the light will be off.
Vector
abela (05-14-2013)
I purchased 2 chargers from: Smartchargers Canada One for my XKR and the other for my G37.
Order the Optimate 6, TM-181 - Optimate 6 5Amp Sealed Desulfating,
they are excellent battery chargers and maintainers. They will actually restore a damaged battery, and disulphate the battery. Very intelligent.
TM-181 - Optimate 6 5Amp Sealed Desulfating.
They come with a pigtail connector which you connect to the battery and leave the charger connecting plug in the tuck for quick and easy connect/disconnect.
I researched many battery chargers/maintainers and these bad boys had the best reviews and results and I can't complain.
abela (05-14-2013)
Hope this helps,
Stuart
Hope this helps,
Stuart
That thread with the pictures was VERY helpful... my car is even the same color !
FS[MidWest]: 2010 XKR convertible
JaguarJoseph
09-16-2015 11:19 AM
Minndavid60
11-09-2011 08:52 AM
