Tried my hand at upgrading the brakes
Picked up some of those nice no/low dust pads and went to put them on the xkr yesterday. Got the wheel off, but could not get the caliper off to save my life. The rotors have a lip on the edge from wear. It's not large, less than .5mm, but I could not get the piston to retract at ALL to come over the lip. I tried everything I know, I've done many brake replacements over the years, but this one just wasn't happening.
Buttoned everything back up, and taking it to the shop this week. I was really surprised, I even opened the bleeder but did not get anywhere at all. I pried it, hammered it gently, pushed on the piston, but nothing.
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Received 2,015 Likes
The rear caliper is a 2 piece set up and you cannot just push in the piston. You would need to unbolt the rear piston caliper from the bracket . The caliper will come off and the pads will remain in the bracket. In order to push the pistons in you need a special tool that both screws in the piston while putting pressure on it. Also before you start taking things apart I assume you made sure the EBrake was off and you could remove the cables. There is a procedure to do that without having the Jaguar system plugged in to back out the EBrake motor . I think there was a post here somewhere so if anyone remembers maybe you can point it out.
I never use my ebrake, I just put it in park, it's very flat here so seldom an issue.
I did make sure I could slide the caliper/pads around on the rotor, it was lose enough to move. I unbolted the holder part with a 7mm allen wrench, which should have let the caliper come off, even sliding against the pads, however it wouldn't move at all. Maybe I'll give it another look tonight.
Been here, done that. Here you go! ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
https://www.jaguarforums.com/forum/x...cement-136031/
Do this and you'll need to replace the disc, btw.
franksm (02-24-2016)
agentorange
04-16-2022 09:04 PM
