Trouble Changing Wiper blades on 2010 XKR
I am feeling exceptionally lame here. After reading some posts on this forum recommending Bosch and Michelin wiper blades, I bought a pair of Bosch Icon blades from Amazon. What came in the box was a set of 22 A and 21 A blades. What seems to be the issue is that I cannot pass the Jaguar's blade arm far enough through the opening on the Bosch blade because the XKR's blade arm fans out wider than the opening. The set came with no other adapters. It feels like if I could get the arm another half inch farther through the opening on the Bosch it might fit although I can't quite tell.
Any suggestions would be appreciated.
See Post #5:
https://www.jaguarforums.com/forum/x...blades-201878/
Also:
https://www.jaguarforums.com/forum/x...cement-203251/
