Two issues - ped system, headlight
1. Pedestrian System error triangle
2. Headlight adaptive lights error light flashing
Hooked up the SDD and I get these errors.
http://s15.postimg.org/mq40mbz4b/1_1.jpg
http://s15.postimg.org/4kmguja8b/image.jpg
http://s15.postimg.org/nr49bgg3v/image.jpg
Anyone got any ideas on the headlight side of things?
For the first one, B1D68-01, the manual says the same as the SDD, i.e. check the lamp operation; if not OK, check the wiring; if the wiring is OK, replace the headlamp. As far as I know, the adaptive lighting motors, etc., aren't available as separate parts, so it's the whole unit that has to be replaced.
For the second, B100596, it's a small sensor behind the grille, and it looks pretty easy to replace:
![Two issues - ped system, headlight-screen-shot-2014-04-01-06.02.34.jpg](https://www.jaguarforums.com/forum/attachments/xk-xkr-x150-33/78469d1480971947t-two-issues-ped-system-headlight-screen-shot-2014-04-01-06.02.34.jpg)
I suppose it's worth resetting the DTCs and see if they come back, i.e. it's a hard fault rather than some random glitch.
